Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Sep 4, 2012 | 06:29 PM
  #4171
josh4389's Avatar
Thinking 235/35/19 fronts and 255/35/19 rears
Old Sep 4, 2012 | 06:34 PM
  #4172
4DGS's Avatar
You'll need a roll and that's it.
Old Sep 4, 2012 | 06:36 PM
  #4173
josh4389's Avatar
Solid thanks for the help. Hopefully this doesn't look dumb
Old Sep 4, 2012 | 06:37 PM
  #4174
Dcampos662's Avatar
Originally Posted by 4DGS
Fenders rolled? I'd suggest just measuring how much room you have, a 20mm is what I have in mind but there are variables that will determine what size to run.
The springs aren't going to be valved correctly for the coil struts and are likely valved sitffer than the Teins.
However, Teins are notorious for being very soft. What coils are you running?
Use the search, there are tonnes of threads where everyone shows their wheel and tire specs with photos.
rear will probably rub strut...
You need a thinner wheel in the back if you don't plan to poke.
Sorry ment they are soft .. But have tein basics on my G .. Also have a set of h&r springs sitting in my garage ... Would I be able to run the H&R lowering springs on the tein ?
Old Sep 4, 2012 | 06:39 PM
  #4175
4DGS's Avatar
Ohhhh yea, was gonna say I've never heard of anyone that thought Teins were too stiff lol
I'm unsure if the H&Rs will seat on the struts, and they're kind of unknown rates paired with the valved struts so it would be an experiment to say the least.
Old Sep 4, 2012 | 06:54 PM
  #4176
Dcampos662's Avatar
Well I'll give it a try if not then I'll use stock shocks w/ H&R and sell my teins and buy a better stiffer set .. Any recommendations?
Old Sep 4, 2012 | 10:20 PM
  #4177
4DGS's Avatar
BC and megan for the budget coils.
HSD and Stance for quality coils.
Old Sep 4, 2012 | 11:45 PM
  #4178
Dcampos662's Avatar
Yea this isn't gunna work lol .. Well I'll try and sell the coils and run the springs for now
Old Sep 4, 2012 | 11:46 PM
  #4179
Dcampos662's Avatar
Ur lowered on?
Old Sep 5, 2012 | 12:03 AM
  #4180
dominate's Avatar
Originally Posted by dominate
I wasn't planning on getting 245/40 on the rear because of the speedo difference, was thinking maybe 235/45 all around?
4DGS,
I used my GPS today and I'm only around 1 mph too slow at 60mph. I dont really mind that, and the beefy (yet oversized I know) tires in the rear look pretty good to me, do you think it's fine if I run my 225/45 front 245/45 rear despite front being smaller than oem and rear being larger than oem? Not going to cause any mechanical issues right? Thanks
Old Sep 5, 2012 | 03:09 PM
  #4181
4DGS's Avatar
No you'll be fine, just looks a little off, that's all.
Old Sep 5, 2012 | 07:23 PM
  #4182
buffhulk's Avatar
19x9.5 +12 10.5 +17......will it fit on my 04 g35 and will it look nasty?
and will it clear my brembos
Old Sep 5, 2012 | 08:19 PM
  #4183
roaminggnome's Avatar
04 coupe.....Finally got some wheels for her the other day. But i think im going to end up needing some spacers. Any idea on what i should run? There 18's and i believe there a 40mm offset. Any ideas?
Old Sep 5, 2012 | 08:25 PM
  #4184
Drew113's Avatar
Ban Hammer Expert
you are gonna need some huge a$$ spacers to make that look good
Old Sep 5, 2012 | 08:26 PM
  #4185
cvipgo's Avatar
g37 convertible with sports suspension & OEM 19" wheels (8.5" F off set 43 and 9" R off set 30) with 225/45 and 245/40 tires.
I recently have been looking into anniversary OEM 19" wheels but the problem is these only come in 30 offset for all 4. The two for rear will be fine but the question is for the front wheels/tires:
What's my best option:
1)use same tire 225/45 with 19x9x30 offset wheels
2) use same as rear size tires 245/40 with 18x9x30 offset wheels.
3) Get correct offset and wheel size (19x8.5x43 offset),
Please respond with your educated suggestions.
Thanks
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
