Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#4336
Alright guys I'm looking for some feedback here. A little over a month ago I posted in the Who has Varrs thread. I got quite a bit of help from two members there about wheel fitment concerning the ES112. Im bringing my questions here because I'd like show interest in other wheels. So here is where im at.
Black G coupe
OEM 17s
BC Coils
Rear SPC camber/toe kit
Nothing up front
Lowered 2" F/R
-2.3 front camber
-3.7 rear camber
No front fender work
Plans to roll the rears
Looking for Flush fitment or depending on the wheels, a little tuck
Looking at Gunmetal or Polished wheels
Super Concave or BIG lips
Budget for wheels AND tires around $2,000
Currently im eyeballin Stance SC-5
19x8.5 +15 F
19x9.5 +20 R
Thanks!
Black G coupe
OEM 17s
BC Coils
Nothing up front
Lowered 2" F/R
-2.3 front camber
-3.7 rear camber
19x8.5 +15 F
19x9.5 +20 R
Thanks!
Look for specs around 9.5/10.5 low teens or single digit positives if you're looking to stretch.
How much camber you plan to run? Looking to stretch I'd assume?
If you're not sure on all fronts, how low do you plan to go?
Not that flush, but sorta flush. Front fitment will be terrible you'll want a 20mm spacer at least. Rear will need at least a 10mm.
#4337
okay guys,
I had wheels that were 19x10+27 in the rear with 255/35/19 tires and am looking at some new wheels that are a bit more aggressive. The ones i am looking at are 19x10.5 +24. I have my rear fenders rolled currently and was very close to rubbing with my previous setup. Would i be able to run these without having to pull my fenders? What size tire? I was thinking of 245/35/19 but not sure if that is too much of a stretch.
edit, also guys a question about re-polishing/repairing lips. They are volks and have some curbage. Are volk lips able to be re-polished? Are they clear coated or clear anodized? Also, are the volk GT-v faces removable?
#4339
#4341
Buy some used 3 piece wheels from the marketplace for $2000. Not some chinese ****.
Ahh ok, well you can fit literally anything you want on the coupe (especially with the help of kevin)
#4343
okay guys,
And yes the GTV faces can be removed, and they can be polished but you will need to polish all four as they are anodized.
which offsets are best for my 05 g35 sedan? and tire sizes?
http://elementwheels.com/proddetail....s%2Dcv31910sil
Yeah 4DGS I've been searching for a while now. Here on Driver, my350z, Zilvia.net and my local craigslist. I DO find some good deals. Problem is they all seem to be on the west coast and don't want to ship LOL. Here in nashville it's all about hondas and lifted trucks. It makes searching for decent wheels a PITA! I really like the Stance Sc-5 but they just aren't aggresive enough. I dont like the idea of dropping 2k on wheels and STILL have to run spacers for fitment reasons. I'd rather do it right the first time.
You don't even need an alignment when you mount new wheels.
You don't need to do anything to mount those wheels onto your car.
#4344
hey 4DGS
here's a pic of the type of stance I want my 05 sedan to be like with the vossen wheels
http://www.iputinwork.com/wp-content...arianzat1s.jpg
vossen wheels link
TIA
vossen wheels link
TIA
#4345
My rear fenders are rolled, but not completely flat. Am planning to get it rolled again to as flat as possible.
I have decided to go with a larger lip size for the rear, so now my choice is:
F: 19x9.5 +15 (R-disk) /w spacer to clear brembos; 235/35/19
R: 19x11 +10 (O-disk) 265/35/19
As for the front drop I'm going to go a little less, as I now think 1.5 may be too much for me, I'm going to say about 1" or 1.25" at most. Rear drop about 0.8"
Will I need to pull a little for the front or rears?
Also, I haven't touched my front fenders at all but they seem to be already rolled (do they come factory like that?) so I haven't thought about rolling the fronts at all.
#4346
hey 4DGS
vossen wheels link
TIA
vossen wheels link
TIA
Run 225/35 and 245/35.
Roll fenders totally flat and maybe a very mild pull to reduce camber.
May need a 10mm spacer in the front but that will depend how low you go.
I'd suggest buying camber arms now for the fine tuning.
Thanks for the reply people!
Fronts do come pre rolled and should not need any additional work with those specs.
#4347
Okay people,
I have a choice between two sets of wheels and am not sure which to go with
Set 1: Volk Gt-v with no tires that need some repair and a repolish for about $1400 locally. I can probably get them repolished and repaired for $200 bringing it to $1600 for an aggressive set
Front 19x9.5 + unkown
Rear 19x10.5 + 24
Set 2: Mint condition Work Vsxx with Achiles tires for $2500. These are not as aggressive and I will need a 10mm spacer up front but they are in perfect shape. Burning black is the color
Front 19x9.5 + 28
Rear 19x10.5 +29
Rear 19x10.5 + 24
Front 19x9.5 + 28
Rear 19x10.5 +29
#4349
Okay people,
Rear 19x10.5 + 24
Front 19x9.5 + 28
Rear 19x10.5 +29
Rear 19x10.5 + 24
Front 19x9.5 + 28
Rear 19x10.5 +29
The GTVs are a pretty sweet deal for $1400, you should just buy those and flip them for a $400 profit lol can easily get $2000 out of those with freshly polished lips.
Really comes down to the style you want, they're both good set ups that can be made to work no problem (but I would get him to figure out the front offset on the GTVs just so you don't get shafted with a 9.5 +30)
Only advantage I see of the VSXX is the fact they're 3 piece, but that's not relevant if you just plan to bolt them on.
Go with the wheel you like more, both deals are solid.
Yup, can always add camber as long as the wheel has clearance on the inside (clearance to the strut)
