Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Dec 9, 2009 | 11:35 PM
  #481
jakz0rz's Avatar
Originally Posted by HXS
do you want to keep those tires? if you do i'd go with 10" front and 11" rear.
if not, go with 9.5" front with 235/35 and 10.5" rear with 275/30.
R-disk front and O-disk rear.
offsets: single digit positives for front and rear (or negatives, if you got ***** )
your car's gotta be slammed to pull off the look.
I don't have to keep the tires! 235/35 sounds good for the front, but I am curious why you chose the 30 series for the back?
This set up looks nice, but looks like there's room to go a little more (single digits like you say sounds good!) ; however, he's not running brembos
Thanks for the comments about the photos nfsp1
Old Dec 10, 2009 | 11:55 AM
  #482
Pepper's Avatar
to me, 275/30/19 on a 10.5 is mild stretch. that's what you wanted right?
265/30 would be moderate stretch.
+17 and +18 offsets for GT-S are usually 9.5 and 10.5 widths.
I was looking for a little poke... 245/35/19 & 265/35/19? less? more? My front wheels could use a little more spacing compared to the rear. Anyone here know of anyone with GT-S's that are spaced?
Old Dec 10, 2009 | 11:10 PM
  #483
imjackiechan's Avatar
shane! i need to roll my rear fenders! i jus put 25mms on the back so pm me pleaseeeee
Old Dec 11, 2009 | 02:41 AM
  #484
thenameistuan's Avatar
Volk Sf Challenges at +23 for fronts and +15 in rear. Any 1 got a pic of these? Most ppl go with the +28 front +23 rear with the challenges but i wanted to go a bit more aggressive so i was wondering if they'll be ok and would i need to roll the fenders? and i do plan on dropping the G
http://gruppe-s.com/Volk/volksfc.htm
thats a site for the sf challenge off sets plan on going 19x9.5 and 19x10.5
Old Dec 11, 2009 | 03:56 AM
  #485
nikkaitsme's Avatar
20x9.5+13 front O-disk
20x11+19 rear O-disk
how aggressive is that? noticeably aggressive? im also lowered 1.4 front and 1.2 rear...i know i will have to roll fender. what tire size should i run? 245/30/20 front and 285/30/20 rear?
Old Dec 11, 2009 | 02:21 PM
  #486
LightsOut's Avatar
SIETESG
gets my approval! you'll have to run some more camber in the rear.
Old Dec 11, 2009 | 06:35 PM
  #487
Karma's Avatar
I would go at least 275/35 in the rear
Old Dec 11, 2009 | 09:02 PM
  #488
HXS's Avatar
HXS
35 series in rear is too meaty if you're gonna do 235/35 or smaller up front.
245/30 is really thin on a 9.5, so i'd go with 275/30 (instead of 285/30) in the rear. less chance of rubbing and cheaper also with the 275's.
you gotta be slammed though cuz 30 series are really thin. there'll be a gap between fender and wheel if you're not slammed.
Old Dec 11, 2009 | 09:31 PM
  #489
nikkaitsme's Avatar
^so what would be better to run in the front?
Old Dec 11, 2009 | 09:46 PM
  #490
LightsOut's Avatar
SIETESG
245/30 is fine up front
285/30 is also fine in the rear. putting 275 on a 11.5 wheel is a big stretch.
if you dont want stretch look for the rear you can run a 305 tire if you like
when running 20's wall size should be 30, on 19's wall size is 35.
Old Dec 12, 2009 | 12:47 AM
  #491
jomamahama's Avatar
Spacer size question with two scenarios:
Scenario 1
Currently I'm on OEM 19's on 06 G35 coupe sport
Stock tires: 225/40/R19 front and 245/40/R19 rear
No drop ever planned
Will Ichiba V2 spacers 20mm front and 25mm rear work without rubbing?
Scenario 2
OEM 19's with Vredestein Sessanta's
245/35/19 and 255/40/19 (no wider as per Redlude's instruction)
Will Ichiba V2 spacers 20mm front and 25mm rear work without rubbing? should I go smaller since the tires are wider?
Thanks!
Old Dec 12, 2009 | 10:00 AM
  #492
LightsOut's Avatar
SIETESG
There's a whole thread for wheel combo and spacer size for oems, including if rubbing will occur.
Old Dec 12, 2009 | 11:23 AM
  #493
jomamahama's Avatar
Angry
Originally Posted by ShanesG
Ok so maybe to prevent all these threads that have been poping up lately asking the same questions about offsets, widths, tires, camber, etc. I figures we could try and clean it up by just throwing all the same general questions into 1 thread.
Ask away...
Scenario 1
Scenario 2
Thanks!
I've searched and looked through the 6 pages displayed in the wheels/tires forum and my specific scenarios were not addressed.
I also posted in the sticky which is the designated place for questions to prevent redundant threads.
Now you are refusing to help me because you believe my question is redundant and you don't even provide a link? Are your 4530 other posts just as useless?
If someone could answer other than LightsOut (now that he might give me incorrect advice to spite me) please post and address the tire width increase between both scenarios! Thanks.
Old Dec 12, 2009 | 12:25 PM
  #494
LightsOut's Avatar
SIETESG
I would help you with a link but posting from my phone will take to long.
To answer your question! You won't rub.
Search better and try different ways of selecting your words when searching. Search feature isn't to great.
Old Dec 14, 2009 | 09:29 PM
  #495
Invader671's Avatar
GramLights 57Optimise Rims 17X7.5 +43offset 5x114.3
I'm kinda a newb on getting some rims for my car..I was wondering does anyone know if these rims will have clearness on my stock 03 brembos..?Been trying to check online but no luck..thanks in advance
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
