Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#5656
Thanks man. Last question.. Would the wheels have to be disassembled to blast and pc them? Or is it done while assembled. Because since they're 3 piece. I'm
Wondering if it'd be difficult to assemble back again. Would make think twice about who I have do the job. A local guy told me 60 per wheel but I'm not sure he's ever delt with 3 piece wheels. Thanks again
#5657
hey guy i have another will it fit question for you.
i was looking at wheels at 18x9.5 or 18x8.5 offsets available are 35, and 20. for both the 9.5 and 8.5 width wheels.
i was thinking 18x9.5 +35 in front and 18x9.5 +20 in the rear. rears is rolled but not flat. front has no fender work. what do you think about that setup?
or should i go 18x8.5 +20 front and 18x9.5 +20 in rear? thanks for all of your help
2006 sedan, thanks.
2006 sedan, thanks.
#5658
Received 1,939 Likes
on
It's very easy to disassemble wheels.
#5660
on
#5663
#5664
on
#5665
I hate to sound like a noob but I need a definite answer for my buddies 06' G35x, he recently got a flat tire in the right rear wheel and that tire cannot be repaired since the hole is in the sidewall. So the question is can he just replace 2 rear tires as opposed to all 4?
I told him he should be fine because the car is 4WD not AWD, but I just need to make sure. Thanks in advance!
#5666
Hey, I have a question about lugs for my wheels.
See, I own a 2003 g sedan, and have gotten the oem 19" coupe rays from a 2006 g.
My question is, what kind of lugs should I use to fit these on my g sedan, as when I bought it, it came with some really ugly rims and cheap lugs. Thanks in advance.
#5667
Help!! Will i have camber issues if ??
i bolt on these wheels
Bolt Pattern: 5x114.3 Rim Width: Front- 19X8.5 Rear - 19X10.5
Rim Brand: STR WHEELS Rim Diameter: 19
Rim Structure: One Piece Offset: +17 / +22
Hub Bore: 73.1 Number of Bolts: 5
i have a 04 sedan im going with H&R springs i did some research just cant find an exact answer i dont want camber issues or have to roll my fenders if this doesnt work shoot me a rim size with off set that wont give me trouble but will give me some good stance thanks fellas!
