Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old May 8, 2013 | 11:29 PM
  #5671
TORETTO's Avatar
Originally Posted by fbasshead
Hey, I have a question about lugs for my wheels.
See, I own a 2003 g sedan, and have gotten the oem 19" coupe rays from a 2006 g.
My question is, what kind of lugs should I use to fit these on my g sedan, as when I bought it, it came with some really ugly rims and cheap lugs. Thanks in advance.
OEM lugs.
Old May 9, 2013 | 10:56 PM
  #5672
ss284's Avatar
Planning on running 20x9+15 up front with 245/35, slightly rolled fenders and SPC camber kit, lowered only 1.5 inches right now. Should a 10mm be enough to sit fairly flush? I need a 5mm anyways to clear oem brembos.
Old May 9, 2013 | 11:11 PM
  #5673
TORETTO's Avatar
it will be barely flush. need at least 20x9 -10
Old May 9, 2013 | 11:58 PM
  #5674
ss284's Avatar
-10? Damn ill need to throw is some camber and step down to a 235/35
Old May 10, 2013 | 12:11 AM
  #5675
ss284's Avatar
What about rear, 275/35 or 275/30? 20x11 +20 same 1.5 inch drop and just natural camber, no roll.
Old May 10, 2013 | 10:53 AM
  #5676
fbasshead's Avatar
Originally Posted by TORETTO
OEM lugs.
But which kind? the 2003 original style for my sedan? or the 2006 coupe style for the rims?
Old May 10, 2013 | 11:01 AM
  #5677
Edwadowad's Avatar
Thinking of picking up a new set of wheels. Currently running on BC coils and all fenders have already been rolled flat.
Just wondering if I'll have any rubbing/clearance issues.
Wheel Specs are:
20x9.5 - Front +0
20x10.5 - Rear +0
Tire Specs are:
Fronts - 225/35/20
Rears - 245/35/20
Old May 11, 2013 | 05:12 PM
  #5678
AmusingG35's Avatar
Xxr 526
Any body work needed to fit these? I think the specs are 20x9 20x11 +13 all around. If you're slammed?
Old May 12, 2013 | 01:01 PM
  #5679
brian8064's Avatar
Axis Penta
I really like the look of the discontinued axis penta. They are still offered on ebay at 20x9 20x10 @ 25f 25r. The tires offered in the package are 245/35/20 & 275/30/20. Can anyone confirm if these will fit properly on a 35 coupe with stock suspension with brembo? Thanks for the help.
Old May 12, 2013 | 01:10 PM
  #5680
TORETTO's Avatar
it should. if not, run spacers.
Old May 13, 2013 | 04:11 PM
  #5681
Fourlix's Avatar
Michelin Super Sport 245/35/19 & 275/35/19 on stock rays?
The diameters are the closest match to stock, but the Michelin specs call for a 9" wide rim for the 275s and the rears are only 8.5". That's close...Is it close enough? Not lowered, stock 19" rays,,,,Can I run these tires? And by the way, I really like these Super Sport tires and would highly reccomend them. I had the PS2s previously, these stick better, last longer and are a little quieter. Oh, and cheaper, What's not to like?
Old May 13, 2013 | 05:18 PM
  #5682
Big Booty Trudy's Avatar
Highest offset for a 10.5 in the front to avoid any issues? Just curious.
Old May 13, 2013 | 06:18 PM
  #5683
Plur's Avatar
^i don't think anyone can answer that question lol.
Old May 13, 2013 | 06:21 PM
  #5684
Lol. Well I was just curious because I'm sure a +20 wouldn't be possible right? Because of all that inner wheel? I was thinking of maybe a + 5 but wasn't sure if that'd give me issues.
Old May 13, 2013 | 06:30 PM
  #5685
Plur's Avatar
10.5 +5 is doable with slight camber and stretch. But you might need to remove your fender liner hardware.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
