Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Jan 15, 2014 | 03:58 AM
  #6736
lowblocks's Avatar
All I want to know is will a 19/10.5 +25 fit on the g35 sedan and sit under the fender
Old Jan 15, 2014 | 09:59 AM
  #6737
ekrebs's Avatar
Its will depending on tires. Im on 255s on a 10.5 with +25. U wanna roll your fenders if ur going low.
Old Jan 16, 2014 | 08:35 AM
  #6738
hdilla's Avatar
Thumbs up national help a noob day
I should be fine with any of these setups right? Also would like your opinions on which ones i should go with..
1.) CE28N Time attacks white/red stripe 19 x 9.5 +22 all around
2.) TE37SL diamond black F:18x10 +20 R:18x11 +18
3.) SSR typef greyish 18x9.5 +22 all around
DG coupe, thanks in advanced!
Old Jan 16, 2014 | 09:05 AM
  #6739
TORETTO's Avatar
Te37sl.
Old Jan 16, 2014 | 11:21 AM
  #6740
hdilla's Avatar
Originally Posted by TORETTO
Te37sl.
Probably everyones answer =p I do like them the most too theyre just priceyy
Old Jan 16, 2014 | 02:28 PM
  #6741
Peter0523's Avatar
Need help
i have 2004 Infiniti g35 Coupe with Brembo breaks
i need some help purchasing the rims
i want to get 20" WORK VS-XX
front 20 X9.5
rear 20 X 10.5
i need to know the offset any suggestion
Old Jan 16, 2014 | 03:49 PM
  #6742
jookyshank's Avatar
I haz hugz to givez
Buy Chris' setup (jdmcain on here )
Old Jan 16, 2014 | 07:41 PM
  #6743
chrisconrey's Avatar
O5 coupe AT I have 18x9 rims with a +35 offset. I can't figure out what my spacer limits would be, can anyone help me out it would be very much appreciated!!!
Old Jan 16, 2014 | 08:15 PM
  #6744
guitarrocker98's Avatar
Well what are you lookiNg for. Flush fitment?
Old Jan 16, 2014 | 09:07 PM
  #6745
TORETTO's Avatar
you can throw up to 45mm in the front and up to 60MM in the rear.
assuming you're running a slight stretch, and have rolled fenders.
Old Jan 17, 2014 | 01:17 AM
  #6746
I do not have my fenders rolled and I'm looking for a flush to maybe a half inch out.. Anyone have any advice on what sizes I should get for my front and back?
Old Jan 17, 2014 | 04:54 PM
  #6747
kchar92's Avatar
I want to lower my car, my tire size is 245/35 20"??
Will there be any scrapping / rubbing issues? I have an 04 coupe. I only want to lower it half and inch to an inch.
Old Jan 17, 2014 | 05:46 PM
  #6748
JC-RH's Avatar
Not enough information.
It also depends on your wheel offset. If you're at about +20ish or higher you should be fine. Anything lower you'll need a fender roll and possibly a pull too. You can avoid this if you run more negative camber.
Old Jan 17, 2014 | 08:51 PM
  #6749
kchar92's Avatar
I don't know the offset. I bought it used from the dealer. It's an 04 coupe on 20" fx35 rims.
Old Jan 17, 2014 | 08:57 PM
  #6750
JC-RH's Avatar
Google fx35 offset. It should be +45 or so...which is very conservative. Plus I think the width is around 8.5 or 9. You will need spacers to avoid it from looking sunken in.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
