Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old May 17, 2016 | 08:10 PM
  #7441
PAIXAO's Avatar
255/35/19 Front Tire
I really hate to ask this but I've searched everywhere and can find countless coupes running a 255/35 tire up front but nothing for the sedans. Can anyone tell me if these will fit properly? I'm currently running a 245/35 up front with no issues so a 255/35 should be no problem.
2005 6MT sedan
19x8.5 Front Wheels with a +18 offset.
Old Jun 1, 2016 | 11:06 PM
  #7442
BTD's Avatar
BTD
Hi, New 08 G35 owner. I know nothing about cars but i recently purchased my G35 and the tire signal and the windshield fluid signal wont go off. regardless of continues air being pumped and released into the tire and constant checking of the windshield fluid and it remaining at the same spot, after filling it to the top. I dont want to go to the dealer and they rip me off, so can someone help, so i will know what to be looking for if i do go to the dealer.
Old Jun 6, 2016 | 10:34 AM
  #7443
lag35driver's Avatar
BMW
Wheel experts,
Do I need to run negative camber with the setup below? My fenders are rolled with after market camber kit. Just want a flash fitment without running negative camber. Thanks in advance guys.
WORK Gnosis GS5
⬆️20x9.5 +15mm 5x114
⬇️20x11.0 +13mm 5x114
Old Jun 6, 2016 | 12:42 PM
  #7444
VenomGT9's Avatar
Depending on tire sizes.
Front may be tight...rear will need a little unless you go super stretched
Old Jun 6, 2016 | 03:13 PM
  #7445
BMW
Thank you sir for the input. I might just go with
20x9.5 +15mm front
20x11.0 +15mm instead of 13 to be safe.
Old Jun 6, 2016 | 03:16 PM
  #7446
Lartytiejdke3's Avatar
lol that wont exactly be a fix..
what tire size?
Old Jun 7, 2016 | 10:22 AM
  #7447
VenomGT9's Avatar
I'm running 285/35 on my 19x11 +15 rear...even will the aggressive roll I doubt I have enough room to get under -1deg of camber...currently -2.2.
Old Jun 7, 2016 | 11:18 AM
  #7448
BMW
I have not order the rims or tires yet. I am just planning it. Will be ordering it next month.
Want to get some experts advise before I order it. Thanks in advance.
what tire size?
Old Jun 7, 2016 | 11:20 AM
  #7449
you gotta talk to us about tires.
stretching? meaty?
whats your goals/plans here...it'll help when you go to pick out specs.
also, do you have a bbk?
Old Jun 7, 2016 | 02:58 PM
  #7450
nicraage's Avatar
newly purchased 2005 G35 coupe base.
Tires are mismatched, looking to replace all 4. I'm working on a Military base in central America, and many of the roads are a hot mess, and am willing to sacrifice performance for more cushion when I hit a pothole.
Current tires: Left front: 245/45 r19; Right front: 245/35 r19; Left rear: 245/45 r19; Right rear (full size spare, unknown); Trunk: Blown out much lower profile than others (probably hit a pothole).
I know the 245/45 r19 is on the front right now, but is that only because the tread is warn down?
Basically, what is the highest profile tire I could put on the front 19" rim, and a good match for the back?
Thank you very much.
Cancel my quetion, I ended up ordering 17" wheels and 225/50 and 235/50's
Old Jun 12, 2016 | 03:41 AM
  #7451
malem's Avatar
Anyone ever run ESR Wheels? I am really liking the look of these ESR SR05 wheels Based on the aggressive wheel fitment thread an 18x9.5 +22 would fit my car perfectly and these wheels seem to be super affordable.
Im new to the G world and just wanted to confirm sizing before I make a purchase
Car is a 2006 G35 Coupe
Old Jun 13, 2016 | 09:06 AM
  #7452
VenomGT9's Avatar
They're affordable because they are poorly made
Old Jun 21, 2016 | 10:17 PM
  #7453
zach57x's Avatar
Liquid Platinum 6MT Coupe
I have the 03 with the 17 inch OEM wheels. I am thinking about getting stanced wheels but I have no knowledge in that field. I just use it as a daily drive and want them to stick out nicely so people notice it. What wheel specs do I have to get or spacers or whatever I need. I do not have the brembos and no sport package. Factory height also. Wheels size I'm looking at 19" wheels
Old Jun 28, 2016 | 12:23 AM
  #7454
Quique0884's Avatar
Need a little assist guys, I own a 07 G35 coupe 6mt. I have H&R coil overs sitting on 20x8.5 and 20x10 in the rear. I don't want to use wheel spacers and I'm shopping around for new rims now. I want to purchase the correct off set to show a nice flush aggressive stance with running into any issues. What off set should i be looking for to avoid wheel spacers? Thanks for the help in advance.
Old Jul 4, 2016 | 10:15 PM
  #7455
SUMBLAKDUDE's Avatar
19x9.5 wheel
Anyone know if the Rohana RC10 19x9.5 will fit on front of G35 coupe non brembo? I know a 9.5 will fit upfront just worried about the spokes of that particular wheel because its concave. The offset is +20.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
