Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#781
All the wheels? Do you know how much work that is? I might as well swap out my rotors and pads too. Maybe i'll upgrade to the 05-06 brakes or brembos while i'm at it. Move on to fixing my compression rods since they squeek. Or how about i change that bad bearing too. I tell you what. Come to think of it, a motor swap at that point isn't a bad idea. Why not just take the whole frame and motor and tranny out and put it in a old 240sx and pull a freak hot rod build. Why not just blow the thing up while i'm at it.
I was making a suggestion since your car is an 03 model and you've had a problem with one of the studs already.
Sorry for making a suggestion to assure safety and save you any future hassles.
I think you need to change your tampon ASAP cause you aren't going to get any help with that kind of attitude.
And no don't blow up the car, just sell it and get an old Civic cause people like you make the rest of us look bad.
#782
#783
good setup. I'd suggest a 275 tire rather than 285.
clearing brembo will be based on the disk type not the offset. I'm not to familiar on that part though.
#785
#787
#788
#792
#794
#795
