Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Sep 22, 2010 | 08:25 PM
  #1216
Bestswat's Avatar
Pretty broad question. I want poke and stretch and not throw off the awd light(no more than 3% difference) at the same time. Is this possible?
Old Sep 22, 2010 | 11:34 PM
  #1217
driver1712's Avatar
Originally Posted by ptd23
i finally figured out my offsets im going to get for my ssr ms1. im going with 20x9.5 +5 NR and 20x11 +11 SL and tires are gonna be 245/35/20 275/30/20
rears are fine...
fronts gotta be either 225/35 or 245/30.
Old Sep 24, 2010 | 06:38 PM
  #1218
tke344's Avatar
How big of a difference % wise can VDC handle before it gets upset? Right now I'm running 245/35/19 fr and 255/40/19 in the rear on my 06 coupe as per many members suggestion (OEM was 225/40/19 fr and 245/40/19 rear - OEM 19"s). VDC is happy and I'm enjoying the handling.
I'm looking to buy a winter setup 17x7.5 wheels with 215/55/17 on all corners.. I know it'll be a little bigger in the front and smaller in the rear overall diameter but would the 2.4% (-.9% front and +1.5% front) difference from stock really matter? To me it seems like the best size for traction in the snow, plus I'd be able to rotate front to back. I'm thinking tire wear and pressure could equate to a bigger difference.
Edit: Now that I think about it and ran some numbers, the setup I'm running now is actually a bigger change in overall diameter from stock than the winter setup I'm proposing, except that the front is smaller and the rear is taller.. I can't imagine this would matter, right?
Old Sep 25, 2010 | 12:08 AM
  #1219
sofla_ball3r's Avatar
im running 20 x 12 in the rear w/ 305/25/20 pirelli pzeros. i need a bit more meat on the tires due to ****ty miami streets. dnt want the 3 piece gfg's gettin beat up. any recommendations on tire size?
Old Sep 25, 2010 | 12:59 AM
  #1220
whoisthis's Avatar
It's so hard to find my answer through over 50 pgs here..lol
Can i run 245 front and 225 rear on stock rims?
Old Sep 25, 2010 | 03:24 AM
  #1221
driver1712's Avatar
30 series?
Old Sep 25, 2010 | 08:58 PM
  #1222
LaserRedG35VS's Avatar
Do Nismo Lmgt4 come Deep Dish? Some pics i saw were deep dish but only like 2. All others weren't.
Old Sep 26, 2010 | 11:21 AM
  #1223
ptd23's Avatar
what color finish you guys think goes best with the ssr ms1's on a brilliant silver g coupe?
Old Sep 27, 2010 | 02:27 PM
  #1224
slickcraft's Avatar
Question Tire/Wheel upgrade for 07 G35x
I would like to switch from stock 17" to 18" and would like to know the correct 18"rim width and tire size. Which brands of tires would be recommended for summer driving only and what gains can I expect in handling/braking. Does anyone recommend changing sway bar to larger diameter?
Old Sep 27, 2010 | 04:14 PM
  #1225
changeover's Avatar
I just had new tires put on and it seems every two weeks or so the tire pressure light comes on, they are low and I fill them and it goes away. Should I get them remounted at a different place or could there be another problem?
Old Sep 27, 2010 | 04:17 PM
  #1226
JBF's Avatar
JBF
might be leaking at the valvestems
Old Sep 28, 2010 | 09:42 AM
  #1227
Regnevelc's Avatar
I'm looking to put 17's or 18's on an 06 Coupe w/ Sports Suspension Package for my winter tires.
I'd like to go down to 215's for the width (front and rear), what tire/wheel size should I be looking at?
Currently I have the 225/40R19 and the 245/40R19's, I assume I'll need to go taller than 40 to keep the same height and keep the speedo honest.
Thanks
Old Sep 28, 2010 | 04:05 PM
  #1228
driver1712's Avatar
super black coat
Old Sep 28, 2010 | 04:34 PM
  #1229
ptd23's Avatar
Originally Posted by driver1712
super black coat
yeah that was my first choice.
Old Sep 29, 2010 | 12:11 PM
  #1230
mmFN's Avatar
2004 G35 Sedan
I gotta '04 G35 Sedan, looking to put some dubs on it, dont wanna drop it, live in the northeast (too many suspension issues), but want a nice aggressive look to it...
I would roll the fenders in the rear if needed...
Do not want to drop it at all, want to keep it factory
looking to go 285-30/20 in the rear and 255-30/20 in the front
Any suggestions????
Of course I would like the car to ride the same or to be smooth at least..
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
