19 inch on my 03' sedan.. need some help please
Old May 16, 2009 | 09:12 PM
saeedibijan's Avatar
i just bought my uncles 03 sedan off of him after totaling my bmw e46 i like the car a lot and it has 19" after maket rims with wider tires in the rear... im not sure the exact size but they stick out past the fender. when i have people in the back and i go over a hump on the freeway or anywhere it bounces and hits the fender. the car is not dropped it just has 19" rims. what can i do to avoid the scraping.. thinner tires? stiffer springs? etc..
let me know what i should do. how it will improve. and how much it will usually cost.. after buying this car i cant really afford much more right now between school and work.
thanks in advance
Old May 17, 2009 | 12:40 AM
gtrefever's Avatar
i honestly dont see how it rubs youve got well from what it looks like 2 to 3 inchs of clearence, maybe just run thinner tires, but those already look thin.
Old May 17, 2009 | 02:42 AM
the shocks are bouncy over bumps so when it comes down it hits the edge of the fender.. im not sure if that means i need better shocks?
Old May 17, 2009 | 03:21 AM
TycoRC's Avatar
Infiniti G35 Sedan Nismo Aero Sport Package
dammmn stunna how do you rub when you are sky scrapin'? whats the tire size?
Old May 17, 2009 | 07:45 AM
ems5332's Avatar
it is a mile hi, you shouldn't be rubbing, you may need new shocks...
Old May 17, 2009 | 08:43 AM
Swivel's Avatar
Moderator
The rears definitely appear to be sticking way out, maybe they are totally wrong offsets that someone threw on there without knowing any better. You should find out the make/model of wheel, determine the offset and figure out if they're even meant to fit this car. You may have to learn what 'offset' is, look it up for your wheels, or determine it yourself through measurements. That's your homework. After that, I'm sure peeps on here will be glad to help you.
Old May 17, 2009 | 12:52 PM
G35sedan03's Avatar
i agree, based on that pic, you are ridin up in the clouds. maybe you had the equivalent of 3 really fat people in the back. looks like you have to look at the shocks.
Old May 17, 2009 | 07:25 PM
the tires in the back are 275/35/19
wideeee *** tires.. anyone else runnin those?
i found out there are some spacers in the shocks in the rear so im gonna try and raise those a bit.. or maybe it need another spacer.. at least i think they are spacers. i was never really into wheels and tires when i had my bmw
Old May 17, 2009 | 07:30 PM
NaiveRapture's Avatar
That tire size is pretty common I believe.
Spacers in the shocks??? OK I'm no suspension wizard but I have no idea what you're talking about. Perhaps you'd make your point better with pictures and / or a better description haha.
Old May 17, 2009 | 09:21 PM
G35sedan03's Avatar
275/35 is a common size for the sedan as long as you have the proper offsets on your rims. i'm running a 285 in the back.
Old May 17, 2009 | 10:15 PM
gtrefever's Avatar
same here spacers on your shocks? maybe you just have some crappy shocks and have no rebound thats why your bouncing like crazy which is causing the rub in the rear
Dallsinghjr1
Sep 17, 2023 11:25 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DRG35R
Jan 31, 2016 07:14 AM
MrIP35
Nov 8, 2015 10:47 AM
Rose M
Oct 12, 2015 10:00 AM
