UNEVEN TIRE WEAR AFTER LOWERING
Old Jul 15, 2004 | 07:15 PM
imRACERX's Avatar
man big problem ive had my spring in for about 7 months and the inside of both front tires are balding. at the time there was only a camber for the rears which i purchased and installed but there was nothing for the front. could it be that the meachanic could have adjusted the camber improperly or that maybe he never adjusted it at all? i assume you can adjust it a little even fr4om stock. i am pretty sure he just istalled the springs (Sprint) and didnt mess with the toe in or toe out. please help. thanks RX
Clear markers w/ hid bulbs, Sprint springs, B&B Exhaust,JL Audio Hifonics combo.
Old Jul 16, 2004 | 05:17 AM
dobbiedoo's Avatar
Re: UNEVEN TIRE WEAR AFTER LOWERING
How much did the springs drop the car? If more than 1 inch then most likely you will need camber adjustments all around.
Old Jul 16, 2004 | 09:20 AM
Kilrmy's Avatar
When the car is lowered the mechanics don't really touch the camber. They just put the new springs on and take it off of the lift. I don't know if, or really think, the coupe comes with stock camber adjusters. If it does you can just adjust it yourself or have your mechanic do it. If not yoou will have to find a camber kit and have that installed. I lowered my coupe 1.2 inches all around and I have not had any uneven tire wear.
Old Jul 16, 2004 | 01:27 PM
Eurog35's Avatar
klirmy 1.2 all around eh? what springs did you use? and did you ever get an alignment? How often do you drive your car, are you using the stock michelins on 18's? Let me know...
how much does an alignment cost anyway?
and can somebody tell me the specs to get my car back into factory specs for the Tein S.techs please. thanks!
Old Jul 16, 2004 | 01:33 PM
Meatshackle's Avatar
Deep Sea Moderator
Need to know if you drive a coupe or sedan to give you the right specs.
Russ
Black 6MT Coupe
Jax, FL
G35Driver.com Business Cards
Old Jul 16, 2004 | 04:43 PM
Eurog35's Avatar
trenta... i drive a 2004 coupe...
Old Jul 16, 2004 | 07:14 PM
Deep Sea Moderator
Hopefully I did this right. It's for an 03 but it should be the same.
Russ
Black 6MT Coupe
Jax, FL
Old Jul 16, 2004 | 09:02 PM
wreck's Avatar
Running for his life!!
<hr></blockquote>
Sorry to hear that man.
I have over 20k miles on my wheels and the wear is even. Even when my fronts are out of spec.
Everyone talks about camber, don't forget toe'ing problems. Having an out of spec toe is far worse than having perfect camber.
Get you car aligned when you get your new tires.
G35C 6MT / CBR600F4I
Old Jul 19, 2004 | 07:44 PM
Notfullwhite's Avatar
Do you guys think there would be uneven tire wear lowered on 20's?
6 MT, Navi, Brembo's, spoiler, 20 inch GT-C's, sunroof, spoiler, crap and more crap.
Old Jul 20, 2004 | 10:47 AM
Kilrmy's Avatar
I lowered my car 1.2 with the Eibach Pro Kit for the Sedan. I have 19" ROH Modena's. In the fron they ar 19x9 and the tires are 255/35/19. The rear is 19x10 and the tires are 275/35/19. I have had no tire wear problems as of yet. Almost a year since I made the mods.
Old Jul 20, 2004 | 12:50 PM
steveinmd's Avatar
EuroG35
Regarding your qustion on alignment cost. I recently had a 4-wheel alignment on my Acura TL at Sears for 59.99. Sears basically adjusts toe, and no more.
I also recently had my G35 coupe aligned at the dealer for $89.99. I didn't get a chance to talk with the tech that actually did the work, so I don't know exactly what was done, or would be done if required, for that price.
Hope this helps.
rezendvous420
May 31, 2020 01:26 PM
obender66
18 Inch
Mar 13, 2016 12:20 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
smokey2
Aug 14, 2015 03:07 PM
BlackGee35
Jul 31, 2015 11:04 AM
