tire size should i stretch?
Old Jul 1, 2009 | 01:22 PM
tightvpkid's Avatar
Its time for me to buy new rear tires and i was wondering what people are suggesting to run with the 19 inch oem rims. Im currently lowered on tein cs and im running 25mm spacers in the rear. The tires are about .5 inch away from the tire wall. the car is sitting right on top of the tire with like .25 or less inch gap. What tire size should i buy without causing it to rub? currently im running oem tire size.
Old Jul 1, 2009 | 01:42 PM
nghiars's Avatar
what size/brand tires are you running now so we can get a better idea.
Old Jul 1, 2009 | 01:44 PM
COMMANDOE's Avatar
Tirerack.com
ask them
Old Jul 1, 2009 | 02:17 PM
gary c's Avatar
Two logical solutions....=)
I'm against stretched tires especially if you actually drive your G. If you have the OEM 19" rims I'd still run the 245s and either get smaller spacers (sell yours) or have your fenders rolled.
Gary
Old Jul 1, 2009 | 02:22 PM
redlude97's Avatar
Roll your fenders, then this wouldn't even be a problem anymore
Old Jul 1, 2009 | 07:37 PM
tightvpkid's Avatar
my fenders are already rolled. Any pros of getting stretch tires? any pictures of a stretch tire on OEM rims.
Old Jul 1, 2009 | 07:39 PM
eurodre's Avatar
i would say..invest some time searching.. there is a HUGE thread on this
and why would you stretch tires on the oem wheels? i personally like stretched tires, but i know the cons associated with them, so only stretch if you NEED to.. don't stretch on oems it will look stupid
Old Jul 1, 2009 | 07:48 PM
tightvpkid's Avatar
i c...not too sure just seeing alot if people stretching there tires. Not sure is there anything really to it, so i was kind of curious what the pros are.
Old Jul 1, 2009 | 07:53 PM
eurodre's Avatar
uhm they don't stretch their tires on oem wheels like i said they stretch in order to fit in the wheels and to keep the rubbing to a minimum.. that is pretty much the only pro, the cons pile up
Old Jul 1, 2009 | 08:21 PM
gary c's Avatar
Already have rolled fenders....next solution!
tightvpkid, apparently you bought spacers that were too big. Replace them with ones that will allow you to run the tires your G came with. We all make judgment errors, don't feel bad....
Gary
Old Jul 1, 2009 | 11:33 PM
redlude97's Avatar
i don't see what the problem is if there is 1/2" of clearance. The widest you can go on the OEM wheels is 255 anyways. There is no way you run into clearance issues
Old Jul 2, 2009 | 01:58 AM
Skaterbasist's Avatar
Retired SuperMod
Only stretch if you need to. And there's no need for that with your setup.
Stretch on the OEM 19's wouldn't look good at all. You would have to run 225 or less on an 8.5 to have any stretch. And I don't see why anyone would run such puny tire sizes.
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
paolojericho11
Sep 11, 2015 07:08 AM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
