Tire Fitment Question
Old Jul 28, 2009 | 04:01 PM
DRG35R's Avatar
20 Year Member
G35 Coupe "Sport Package"
have a set of Michelin Pilot Sport A/S, 245-35-19/275-35-19, mounted on 9.5 and 10.5 rims with no real stretch at all. even though it is not recommened fitment on Tirerack's website, these should be fine for fitment on a 19x10 and 19x11 rims...correct?
has anyone done a fitment like this and have any pics?
Old Jul 28, 2009 | 05:19 PM
nismoz's Avatar
that is the most common tire size for 9.5 and 10.5 rims.
Old Jul 28, 2009 | 06:29 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
245/35-19 will fit wheels 8.0-9.5" wide, the 275/35-19 9.0-11.00" wide. Best not to try and fit them outside the ranges they are built for.
Old Jul 29, 2009 | 07:32 AM
DRG35R's Avatar
20 Year Member
yeah, thanks. that is what they are already mounted on. I was asking about fitment on a 19x10 and 19x11.
Old Jul 29, 2009 | 07:42 AM
DRG35R's Avatar
20 Year Member
but does it not sometimes depend on the cut of the tire? I have some 245-35 Falken Grb-FK451 mounted on a 9.5 and they are stretched to the limit, where as the Michelin Pilot A/S mounted on a 9.5 is not stretched at all.
along the same line with the Falken Grb-FK451, I have a 285-35 on a 10.5 and it is lightly stretched where the Michelin Pilot Sport A/S 275-35 on the 10.5 is almost bulging.
have read where most Japanese and S. Korean manufactured tires are cut a bit more narrow than the US and European manufacturers. I know that Pirelli's and BFG's tend to be wider than the identical sized Toyo's, Falken's and Hankook's
Old Jul 30, 2009 | 01:31 PM
DRG35R's Avatar
20 Year Member
no one here has a 245-35 mounted on a 19x10?
find that hard to believe with all the tire stretching I have seen.
Old Jul 30, 2009 | 02:06 PM
nismoz's Avatar
If you want to mount 245/35/19 Michellin PS A/P on 10" wide rims. I dont think you have a problem. As we know, Michellin tires are tend to be bigger than other tires. But for safety reason, 255/35/19 is an ideal size.
Old Jul 30, 2009 | 04:22 PM
DRG35R's Avatar
20 Year Member
^agreed, but we all know the manufacturers post what is the most safe fitment and people have blown right through those recommendations.
would normally do a 255-35, but I have a brand new set of the Michelins just sitting in the house. the 275 should be fine with a little stretch on the 11" and I figure the same for the 245 since it is not stretched at all on the 9.5. what is a half inch about 13mm. worth a try, these were expensive tires to be just sitting around.
Old Jul 30, 2009 | 04:50 PM
redlude97's Avatar
If you want to do it, just do it. You know what increased risks you are subjecting yourself to.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
Soumilg
Jul 18, 2015 12:33 PM
mushu
Jul 15, 2015 03:55 PM
