ABS, Vdc off, Slip warnings
Old Sep 8, 2009 | 11:46 PM
focheezy's Avatar
I just upgraded to some oem 19's from my 17's, and now the abs, vdc off, and slip lights are on. What does this mean?
Old Sep 9, 2009 | 02:40 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Probably tire size issue. What sizes are you using?
Old Sep 9, 2009 | 02:55 PM
focheezy's Avatar
245/40/19 for rear, and 225/35/19 for fronts.
Old Sep 9, 2009 | 03:00 PM
PLATINUM SPONSOR
Front seems a bit short. Should be in 225/40-19 to keep diameters correct. I'm guessing the inch difference is what's setting it off.
Old Sep 9, 2009 | 03:03 PM
focheezy's Avatar
is it still drive able?
Old Sep 9, 2009 | 03:05 PM
PLATINUM SPONSOR
Not the best idea. Stability control/traction control works off tire diameter and right now the car thinks it's slipping due to the incorrect diameters.
Old Sep 9, 2009 | 03:29 PM
focheezy's Avatar
When i start the car up, the lights doesnt come on right away. I start to drive, i can feel the brakes slipping, still no lights. After a couple minutes the abs, slip and vdc lights will come on, and the brakes seems fine.
Old Sep 9, 2009 | 04:14 PM
teamspink20's Avatar
i would not recommend driving it like that
Old Sep 10, 2009 | 01:00 PM
Higrev's Avatar
aye could be dangerous... might want to get that resolved
Old Sep 11, 2009 | 10:41 PM
rob05G35's Avatar
warning lights
im havin the same problem but my lights dont come on till 65-70mph
Old Sep 11, 2009 | 11:09 PM
focheezy's Avatar
Just put some 225/40/19's on the fronts and the lights are gone.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
markbilo
Sep 30, 2015 01:33 AM
vamarris
Sep 26, 2015 12:56 PM
