Question about 2004 7-spoke rims
Old Sep 16, 2009 | 02:04 PM
csguy0's Avatar
I need new front tires for my car. Currently I'm running 245/45 on back and 225/45 on the front. From what I understand my wheels are the same width... is there anything I should be aware of before I put 245/45's on the front? I want to do this so i can rotate my tires front to back... Seems to me like the sidewall will be slightly higher on the front over the stock size... will I have an issue with VDC?
Thanks in advance...
Old Sep 16, 2009 | 03:28 PM
nghiars's Avatar
it will be slightly higher in the front... just about 2.6% different. I would run 235/35/18 since its right down the middle. they're 1.3 smaller than rear and 1.3 larger than front...
Old Sep 17, 2009 | 09:23 AM
csguy0's Avatar
Bump... anyone know if I can run the same size tire front and back?
245/45/18
2004 6MT Coupe
Thanks,
David
Old Sep 17, 2009 | 10:02 AM
Deezflip's Avatar
yes, the VDC will kick in with all 4 tires being the same size on the coupe. You need to maintain a staggered setup. I believe the current stock tires are 2.7% difference in overall diameter between front and back.
Going with 245/45/18 in the front, you'll need to change the size on the rear to either a slighty wider or slighty taller to compensate the staggered ratio.
Old Sep 17, 2009 | 12:45 PM
nghiars's Avatar
you can run 245/45 all around and be fine.
Old Sep 17, 2009 | 01:04 PM
idrive_MD's Avatar
I ran 235/40 all around and it was fine, never had an issue with VDC except when I pushed it. Now 235/40 front and 245/45 rear had some issues...not recommened and it was only temporary for me.
I plan on using 245/45/18 all around for my winter setup, but hopefully on slightly wider wheels than OEM
Old Sep 17, 2009 | 03:07 PM
csguy0's Avatar
I'm tempted to try it being that firestone has a 30day money back guarantee... Anyone else have any success with this?
Old Sep 17, 2009 | 03:10 PM
WhosRich's Avatar
Its pretty clear to me from everyone's post here that it will not work, atleast not the way you want it to.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Srinidhi
Aug 7, 2015 03:38 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
vstypicals
Jul 20, 2015 10:55 PM
EasySausage
Jul 14, 2015 11:17 PM
