Do spacers ruin aerodynamics?
Old Oct 28, 2009 | 07:10 PM
azt108's Avatar
I was wondering if anyone with some technical knowledge would know whether or not spacers have any effect on the aerodynamic characteristics of the car. Sure it looks cool, but my guess is that when the tire is sticking out beyond the body, it is creating drag.
Anyone have any experience with this?
Old Oct 28, 2009 | 08:55 PM
nghiars's Avatar
the guys running those strectched look with negative camber anbd wheel pokage are already sacrficing perfonce for looks... I doubt they'll care about a little drag.
I really cant answer your question because i really dont know if being half an inch to an inch out is enough to cause drag.
Old Oct 28, 2009 | 09:06 PM
jookyshank's Avatar
I haz hugz to givez
Per logic as you said, any protruding surfaces (especially flat to the air flow, which tires would be) will cause drag...
As to "felt effects" I doubt it matters until deep into the speed limiter range and I echo, anyone pushing their tires out that far, probably aren't worried about any speed detraction they get from the setup
Old Nov 14, 2009 | 03:44 PM
Ray@OCInfiniti's Avatar
everything affects aerodynamics, EVERYTHING.
will it be anything you will ever ntice or need to concern yourself with NO.
the difference is SOOO minute (with correct sized spacer installed that is), that it's not worth the breath to discuss I do not think.
Old Nov 15, 2009 | 02:07 PM
itgogitrev's Avatar
Yes it does. But it's not enough to warrant the thought of not getting them.
Old Nov 18, 2009 | 06:11 PM
Skaterbasist's Avatar
Retired SuperMod
Completely negligible. That's something I wouldn't worry about.
Old Nov 18, 2009 | 06:19 PM
sammy_G's Avatar
reducing parasitic drag is always a plus..
theoretically you'd want flush fitment to reduce seperation bubbles and huge drag vortices along the side of the car.
but then you have to decide at what speed do you want to be optimized for
translation: dont worry about it
Old Nov 18, 2009 | 06:28 PM
JOKER's Avatar
CLUB MODERATOR
You are driving a G and not a Boeing 787
Old Nov 26, 2009 | 11:18 PM
Osa713's Avatar
lol seriously though...
Old Nov 27, 2009 | 12:11 AM
PTownG's Avatar
the purpose of spacers is to flush the wheels with the body not to jut them out past the body. We're not lowriders.
Old Nov 27, 2009 | 01:15 AM
AARONHL's Avatar
What size spacer with stock sedan wheels? 20mm?
Old Nov 27, 2009 | 07:17 AM
jwrape's Avatar
Mileage is still the same after my spacers. I don't see the affects
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
