Tire Size Suggestions...
It all depends on your rims & offsets. I'm dropped on Z/coupe springs and I have 245/40/19's all around and no rubbing in the rear whatsoever...and the more weight you have in the back, the more negative camber & LESS fender rubbing occurs. I only rub in the front when hitting bad bumps, but it's tolerable...again, only when hitting bad bumps...normal bumps I'm fine.
