Another Tire Size help thread
Old Dec 2, 2009 | 06:31 AM
Blue Dream's Avatar
I drove ttrank's car solo
I vote for 245/40/19 all the way around. I'm dropped an inch and no rubbing at all.
I like the look and drive better than 35's. You mignt want to think about spacers as well with that high offset. I'm running coupe 19's that are +30 and +33.
Old Dec 2, 2009 | 08:31 AM
lox1985's Avatar
Ye, the offset is making me put 235s instead of 245s. Spacers are still in the works and I'm trying to decide between 5mm and 10mm
Old Dec 2, 2009 | 08:38 AM
psedog's Avatar
Back in SD**
I think you would be more likely to rub via the rim not the tire (in the front). The arm curves in pretty drastically past the rim. Test fit the rim and see if you need spacers. Honestly I think you should get some 10mm spacers for the front.
Borrowing this pic from another thread
Looks like your wheels will be 7mm (.3") closer to the arm.
I plugged the numbers into this wheel/tire calculator
http://www.wheelsmaster.com/rt_specs.jsp
I used
245/35 19 8.5" et38 for his and
245/35 19 8" et45 for yours.
Good luck.
Old Dec 2, 2009 | 09:15 AM
lox1985's Avatar
oh thanks for the info. I'll definitaly put them on prior to getting tires and see how big of a spacer i need.
Old Dec 28, 2009 | 07:11 PM
lox1985's Avatar
Hey guys, just an update.
I purchased Yokohama AVS 245/35/19 all around. Here are some pics and I do need some spacers on the front but not more than 15mm:
And here is how close it is to the control arm on the front:
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
Jnm07
Aug 6, 2015 03:03 AM
reaper76
Aug 5, 2015 10:13 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
