Tire Question
Old Mar 7, 2010 | 02:55 PM
Doruk's Avatar
Tire Question
Hello everyone, I have searched but couldn't find my answer.
I am getting 4 new summer tires for oem 19s.
i wanted to go slightly wider for the tires since they were the same prices with oem sizes.
is it okay if i go with
245-40-19 for fronts
255-40-19 for rears
I have notices people suggested 245-35-19 for the front but i don't want to go with thinner tires since i don't like rougher ride.
BTW i have 05 coupe 6mt and its stock height.
also the best price tires i found here in Ottawa/Canada is KUMHO SPTs.
Can anyone give me their review about these tires if they tried them.
thank you
Old Mar 8, 2010 | 04:17 AM
Doruk's Avatar
bump!
anybody used this setup? i have found many reviews about the kumho tires but i couldn't see any information about this set up.
thanks
Old Mar 8, 2010 | 04:32 AM
rooring husky's Avatar
Personally I wouldnt go as wide in the front, I would go with maybe a 235/40..
For the rear you could easily get away with a 255/40...
I am lowered and am running F 235/40 R 255/40 on stock rays with no problems..(with 25mm spacers all around)..
I checked on the tire calculator and it says that you will be slightly off on the speedometer even with OEM wall size so not sure about that. If anyone can chime in that would be great. Thanks.
Old Mar 8, 2010 | 04:42 AM
Doruk's Avatar
So if i am not lowered and have no spacers, would 235-40 19 fronts and 255-40-19 rears be a good setup?
Old Mar 8, 2010 | 05:52 AM
Blue Dream's Avatar
I drove ttrank's car solo
This thread should answer any questions you have about tires on 19's.
https://g35driver.com/forums/wheels-...ll-thread.html
Old Mar 8, 2010 | 09:40 AM
gary c's Avatar
You should have no problems running the 245/40F and 255/40R. I've never understood why Nissan likes to put those smaller tires on the front anyway except for less rolling resistance and better gas mileage? Who cares about that?
Gary
Old Mar 8, 2010 | 09:48 AM
danielj's Avatar
From: Winnipeg, MB (Biggest/Coldest city in the world)
The reason why your speedo might be slightly off (from what i have heard) is that the the second number is the ratio of the width of the wheel to the height of the tire itself. meaning if you stay with a 40 (second number) and move up to a 255, then your tire's wall (or height) will be slightly larger then it was with stock 245's.
Old Mar 8, 2010 | 10:18 AM
herrschaft's Avatar
^My speedo is 1.5 - 2mph off because I have 245x35x19 all around. I would go 255's if I wasn't getting wheels soon. If you like to rotate your tires than keep them all the same. IMO 255's all around would look better.
Old Mar 8, 2010 | 11:38 PM
Doruk's Avatar
I have read almost entire thread there and my question was asked couple times with excat same sizes but never answered. so i am looking for my answer here bud.
Old Mar 8, 2010 | 11:41 PM
Doruk's Avatar
Hey Gary, thanks for your respond.
I don't care about the gas mileage
Would there be a difference between these two sets?
235-40F and 255-40R than chosing 245-40F 255-40R
I am between these ones if there is nothing wrong.
is there any fact that would make one set better than another?
is it better to go slightly wider front then narrower.
thanks
Gary
Old Mar 8, 2010 | 11:45 PM
Doruk's Avatar
i wouldn't mind slighty off speedo, but you have mentioned that the tire height will be larger would it make the stock height vehicle look worse?
Old Mar 9, 2010 | 01:33 AM
gary c's Avatar
When I had my 18" I ran 245F & 255R without any issues and my coupe handeled very well.
Gary
Old Mar 9, 2010 | 01:47 AM
danielj's Avatar
nah, its a super small amount, like one of the others said, there speedo was off by 2 mph and i'm sure thats only when there doing like 70 mph, so its like a couple percent really.
I wouldn't get bigger then 235 in front unless you really need/want performance, it'll really get more expensive for both the tires and the gas themselves. 235's and 255's would look nice on stock rims with like a 10 mm spacer in front and 15 in the back. I was thinking of doing that myself, but i'll be sticking with the 245's in the back, i just ordered a set of hankook ventus v12's for the rear myself, look fairly aggressive and are better then oem in everyway according to Neal from Tirerack.com (great guy, call him to order).
If you go to aftermarket wheels i'd allow 245's no problem maybe even 255's in the front, but only if you are going to mod your car to 330 hp and higher (meaning you pretty much have to have a turbo or supercharger) , otherwise its a little bit pointless in my opinion. No bigger then 275's in the back, but i'd reccomend like 245 and 265 if possible on an aftermarket rim, looks great but is still reasonable.
just my opinion, but what would i know, i'm just a doctor.
(no, i'm really not, not even close, won't ever be either, unless its like a phd in commerce lol)
Old Mar 10, 2010 | 08:15 AM
Dr. Jekyl's Avatar
I was wondering the same question, and I'm glad that the OP's question was finally answered. I'm now thinking of going with 255's all around.
Old Mar 10, 2010 | 12:27 PM
Doruk's Avatar
Finally i have decided to go with
235-40-19F
255-40-19R
and with kumho spt tires
stock height no spacers oem wheels
any comments? suggestions? do you guys think that it is a good set up?
