help with tire pressure sensor
Old Sep 28, 2004 | 10:39 AM
twilightG35's Avatar
hi to all,
i was wondering if anyone can help me out with the tps light on the cluster. ive been rolling around with my 19s (245/35, 275/30) for about 6 months now with plenty of tread and out of no where the light just turned on. not once since ive put my wheels on has the light came on. ive put more air in the tires and the light is still on. its been on for 2 days now. is there a way i can reset the light. btw ive disconnected the battery as well, still there. i know it wont harm anything but it just bugs the hell out of me everytime i look at the cluster and its lit up. any ideas would be help full thanks.
gg
Old Sep 28, 2004 | 03:34 PM
xswl0931's Avatar
Re: help with tire pressure sensor
So you installed your old TPS in your new 19's? What psi are each of your tires?
Old Sep 28, 2004 | 03:39 PM
no the old tps where not installed on my 19's. i never seen that light turn on once since ive had them on for about 6 months. im actually at max psi as of today.
Old Sep 28, 2004 | 03:53 PM
THX723's Avatar
G Kreuzer
Then you will have to live w. the warning light ... at least until a way to gracefully disable the system is found. The computer does check the status of ALL sensors periodically. If no answers are received due to either damaged or missing sensors, the warning light is illuminated. I'll go away after sometime.
Clint (THX723)
Old Sep 28, 2004 | 04:18 PM
do you think doing the pedal technique will reset that light? btw thanks for the info!
Old Sep 28, 2004 | 08:02 PM
glennp_1999's Avatar
Or you can open up the gauge cluster and remove the light bulb. Damn did I just suggest that? Disregard!!!
<font color=blue>04 CB COUPE / WILLOW / PREM PACK</font color=blue>
Old Sep 28, 2004 | 08:26 PM
BLICX13's Avatar
Just a comment on your post - you stated that your tires where at max psi today??? A tire is not designed to have the stated amount (on side wall) of maximum pressure - and bve driven around - very unsafe... but maybe I misunderstood...
Old Sep 29, 2004 | 02:19 PM
dholly's Avatar
wait - you replaced wheels 6 months ago with no transmitters, and your TPMS dash light JUST went on?! lol
2004 | 6MTs | Diamond Graphite/Graphite
Upstate NY
Old Sep 29, 2004 | 02:41 PM
yeah i was kinda surprised it went on after 6 months. i was expecting it to go on when i first put the wheels on because i know the recommend tire size for the rear wheels is suppose to be 275/35 and im running a 30. oh well im on my stocks now gona run them for a few days than put the 19s back on to see if the light stays off. lolz
jsimonk
Dec 22, 2023 03:49 PM
Muski_G
Dec 1, 2023 11:11 AM
joedaddy1
Jul 28, 2015 02:58 PM
stay_tuned
Jul 21, 2015 07:09 PM
