neg camber+wide wheels+noise=????
Old Jun 9, 2010 | 09:28 PM
the_sedan's Avatar
in the market for some rear tires as mine are at the wear indicators on my falken 452s. these tires have been good for the most part, the fronts got a tad noisey due to some cupping, but overall life is/was good if you drive normally. i've been looking into the nitto nt555, hankook v12, and now after readin the review thread......maybe the nankang ns-2? the kangs are half as much as all the other tires. i just wanted to know what some of yous guyssss reviews are with the tires you ran/are running with some negative camber and wider wheels with a little stretch......as far as wear, noise and comfort?
Old Jun 9, 2010 | 09:34 PM
JBF's Avatar
JBF
generals or vredestein
Old Jun 9, 2010 | 09:53 PM
the_sedan's Avatar
i saw the exclaims...now i see that plenty of people run them so i will have to look into them. as far as the vredesteins....the one tire i saw was an inside/outside tire, not a directional tire. i wanna get directional so i can swap the tires off the rims so i can run the opposite side to get the most life out of them that i can.
Old Jun 9, 2010 | 09:55 PM
Heist.'s Avatar
Running camber leads me to getting cheap tires with thicker sides. Plus if you want some stretch. Generals. Not too noisy but I'm running 35 so comforts out.
My 2cents
Old Jun 9, 2010 | 10:03 PM
i like pzeros, and look sexy stretched
they also run a lil bigger
Old Jun 9, 2010 | 10:15 PM
the_sedan's Avatar
hawtness iseechriss
i mean, i want something decent, but nothing pricey cuz they will wear out faster than they normally should due to my camber and spirited city driving .
well im on 18x9/10 e20 g-games lowered on df210s. currently running 235/40 and 265/35 shoes unless you think a different size would be a lil better?? -2.2F and -2.9R camber settings w/ no camber kits btw.
Old Jun 9, 2010 | 10:24 PM
thanks im actually dropped on df210s but i cut like an inch and half of spring mount so it tucks tire now, and my camber setting is about -3.7/-4.
i dont really know much about tire sizes in 18s, but to me 40 sound a little too tall. but i would run a 225 in front with a 245 in rear.
Old Jun 9, 2010 | 10:37 PM
the_sedan's Avatar
i wouldnt really wanna do too much more of a stretch since im not tuckin so it would look weird. im runnin 15mm spacers all around so im pretty flush, but i have a tad bit of gap so more stretch wouldnt look right unless i was lower and i dont have plans to go any lower. and i had to do a slight roll on the rear cuz they were scrubbin a lil when goin over bumps and stuff.
Old Jun 9, 2010 | 10:47 PM
the_sedan's Avatar
couple pix of me wheelssss
Attached Thumbnails neg camber+wide wheels+noise=????-100_1253.jpg   neg camber+wide wheels+noise=????-2010-05-22-11.13.19.jpg   neg camber+wide wheels+noise=????-100_1255.jpg   neg camber+wide wheels+noise=????-2010-04-03-13.49.17.jpg
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
Thebaws11
Nov 30, 2016 12:54 PM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
