For those who installed their own EDFC
Oct 24, 2004 | 05:43 PM
I was installing my new TEIN CS w/ EDFC last nite, but when I got to the rears, there were no openings to get the wire from the edfc motor above the shock tower. I'm sure some of you guys have done your own install on this setup and I was wondering how did you guys do it? Did you remove the trunk lining out to drill a hole or you went from the inside removing the speaker deck and drilled a hole there? Any pointers would help. I appreciate it.
Thanks!!!
04 Desert Platinum G35C
Premium/Wheel
Upcoming Mods: Eurospec HID projectors Retrofit, ClearBra, OEM front lip, 19" Volk's GT7's, Ings Spoiler
Reply 0
Oct 25, 2004 | 04:38 PM
Re: For those who installed their own EDFC
Anyone?
Premium/Wheel
Reply 0
Oct 25, 2004 | 06:18 PM
I installed my tein cs with edfc. I used a hole saw to cut thru from the passenger compartment to the shock tower. There were a couple of holes (maybe to vent) already there. I just stuck a screwdriver into one of them to see which one worked better.
Just make sure the hole you cut is large enough for the edfc connections to fit thru.
Refer to picture #6 of Profile4's post....https://g35driver.com/forums/showfla...&sb=5&part=all
<P ID="edit"><FONT class="small"><EM>Edited by lucky_menehune on 10/25/04 03:21 PM.</EM></FONT></P>
Reply 0
Oct 26, 2004 | 04:19 AM
Use a unibit to enlarge those holes.....
Certified Window Tint & Detailing Specialists
Certified Paintless Dent Repair Technicians
VentureShield Paint Protection Film Dealer
Madico Window Film Dealer
2003 AT Sedan / 2004 6MT Coupe
Reply 0
Oct 26, 2004 | 12:21 PM
Thanks for the help guys!!! I will post pics when I finished the install!
Premium/Wheel
Reply 0
Oct 26, 2004 | 10:45 PM
yes, use a drill that you can cut approximately a 2" diameter hole in the frame. take a piece of rubber hose and slice it down one side to use it as lining for the hole so they edges won't cut you or the wiring. did you figure out where to run the front wiring thru the fire-wall? as for the rears, i ran the wiring under the carpet along the sides around to meet with the front wiring and mounted the controller in the ashtray so that i can conceal it when its not in use. good luck with the install!
04 DG/G/6MT/Premium/Nav/Clear Bra/19x9.5(f)19x10.5(r) Volk SF Winnings/BFGoodrich 245/35(f)275/30(r)/Tein Flex Coilovers/Tein EDFC
Sponsored by BFGoodrich, Ai Design (www.aidesign.com)
Reply 0
Sep 15, 2008 | 11:58 AM
can you post that pic for the hole for the rear shock towers?
Reply 0
Sep 16, 2008 | 06:53 AM
Something along those lines.
Reply 0
Sep 16, 2008 | 08:30 AM
I used a unibit as well
Reply 0
