Shock & Strut Replacement?
Old Oct 27, 2004 | 07:05 PM
adrenalinepump's Avatar
When should the Shocks & Struts be replaced on the Sedan?? Also what Shocks/Struts to you recommend to switch to??
Thanks!
Check out My Home Page for some Hott Deals!
Old Oct 28, 2004 | 11:22 AM
ABQ_G35's Avatar
Re: Shock & Strut Replacement?
No struts on the G35!
Brilliant Silver/Graphite/Premium/Chrome Wheels '04 Sedan/5AT
Old Oct 29, 2004 | 07:15 PM
dklau33's Avatar
The shocks should be replaced when they are no longer doing their job anymore. You will easily feel that. There is no set timeline to replace shocks and springs. Just replace them when they have worn out and your car is bouncing up and down the road.
04' G35S 6MT Ivory Pearl, Willow, Premium
Z-Tube / NFC Y-Pipe / Custom Mid-Pipe / 350 EVO Rear Sway/ '03 350Z Shocks and Springs
Old Oct 29, 2004 | 08:25 PM
Q45tech's Avatar
Historically, on the Q45, J30, and G20, the oem shocks especially the rear rebound was noticably softer after 30,000 miles and by 60k you could feel a significant difference after replacement especially on rear.
Really depends on bumps per mile and their severity.
Generally passenger side components fail first because that side of road is rougher compared to the road center.
At high mileage the passenger side of subframe [silicone filled bushings] fails first on average 3:1.
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
smartin0924
Aug 13, 2015 07:29 PM
si_driver
Aug 11, 2015 07:08 AM
wuppiedog
Aug 7, 2015 11:16 AM
cyrus32
Jul 18, 2015 06:22 PM
