I suck at wheel and tire sizes
Old Jan 11, 2011 | 05:02 PM
klevr's Avatar
Okay so I'm totally lost and new to this world as I've never purchased wheels or tires before.
I have an 03 Coupe 5AT dropped on Eibach Pro Kit's.
I'm going to be purchasing some staggered 20" TSW Cadwells. They're 20x8.5 in the front and 20x10 in the back.
I was also thinking of getting the Nitto NT555's for tires.
What tire size would I need? I know nothing about tires.
Also, the place I was looking at purchasing them from says that if I get the staggered fitment that the rear wheels will stick out way too far and may cause damage to the fenders or something. Is this true or does this person just not know what they're talking about?
Will I need to get fenders rolled, etc. in order to fit these wheels?
Thanks.
Edit: They are suggesting 235/35/20 in the front and 255/35/20 in the rear.
Old Jan 11, 2011 | 05:05 PM
toymachine2009's Avatar
for people to help you out they need to know offsets..
Old Jan 11, 2011 | 05:12 PM
broke_as_ajoke's Avatar
Hear u can read this.. it will help u understand the questions that u need to know to ask folks.
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Old Jan 11, 2011 | 05:28 PM
klevr's Avatar
Yeah that would probably help.
The front is +40 and the rear is +25.
Old Jan 12, 2011 | 10:35 AM
klevr's Avatar
Am I going to have issues with rubbing? I can get the fenders rolled to give me about another 1/2".
If so, should I go for a different tire or something?
Old Jan 12, 2011 | 02:53 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
More common fitment would be 245/30-20 265/30-20.
Old Jan 12, 2011 | 03:11 PM
klevr's Avatar
Thanks for the advice. What difference is this going to make exactly? Just a little bit of a wider tire to fit the wheel and not quite as tall?
Old Jan 12, 2011 | 03:14 PM
PLATINUM SPONSOR
The 235's are a bit shorter than normal and probably won't have the correct diameter to keep everything working in harmony. They will be a tad wider/taller than what you have in the opening post.
Old Jan 12, 2011 | 03:16 PM
klevr's Avatar
Ahh okay that makes sense. Now will I have a lot of issues with the combo being too tall since my car is lowered? I'm assuming I will have to get some fender work done, but will this all fit?
Old Jan 12, 2011 | 03:18 PM
PLATINUM SPONSOR
No notes from my guys here saying there will be rubbing issues, and I'm sure over the years others using the sizes have been lowered.
Old Jan 12, 2011 | 03:23 PM
klevr's Avatar
Excellent, thanks a bunch. I guess I'll just try it and see what happens!
Old Jan 12, 2011 | 05:31 PM
06g35meister's Avatar
That +40 on the front is really sucking the wheel into the wheel well if im not mistaken, might want to look for something more in the 15-25 range...
Old Jan 12, 2011 | 05:41 PM
Golden_Shower's Avatar
First off if your going to order the wheels order the cadwell front in a +20, your stock wheels are a +30 you want to drop the offset not raise it. Is there a specific reason you want 20's on your car and not 19's, Putting 19's is much easier to deal with.
Old Jan 12, 2011 | 06:06 PM
klevr's Avatar
Good call, I'll definitely get the +20.
I want the 20's because I like the way they look. I'm sure 19's are easier to deal with but there are plenty of people that ride with 20's. I'll find a way to make it work.
Old Jan 12, 2011 | 06:14 PM
Its easy to make them fit you are not running that low of an offset
vitamin.v
Nov 7, 2019 06:10 PM
Jnm07
Aug 6, 2015 03:03 AM
Popes
Jul 29, 2015 05:07 PM
Detailed Image
Jul 24, 2015 12:31 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
