Help - Tire Size
Old Mar 19, 2011 | 12:27 PM
g35 GI's Avatar
Help - Tire Size
I have an 07 G35s Sedan and purchased a new set of rims, 20x8.5 front,
20x10.0 rear. my question is what size tire should I purchase that will not cause any fitment issues i.e. rubbing etc. The car is stock.
Thanks for any suggestions.
Tony
Old Mar 19, 2011 | 02:42 PM
JaysG35x's Avatar
Dont know about tire size but IMO it will not look good with 20" rims without being lowered first. Just my opinion but lower you car before you get new wheels.
Old Mar 19, 2011 | 03:09 PM
4D05G35's Avatar
What are the offsets of the wheels?
Old Mar 20, 2011 | 09:35 AM
g35 GI's Avatar
the offsets are +15 front, +35mm rear.
Old Mar 20, 2011 | 05:46 PM
4D05G35's Avatar
I think that you are going to have to stretch the tires a bit to keep from rubbing.
30mm offset would be more ideal for the front and 45mm for the rear, if you dont want to stretch your tires.
Old Mar 20, 2011 | 08:25 PM
the_sedan's Avatar
245/35 and 275/35 is what my wheels had when they came off a g37 coupe. 20x8.5 +20/10 +25 stock suspension
Old Mar 22, 2011 | 03:23 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
We have always used 245/35-20 275/30-20 with great results.
Old Mar 23, 2011 | 01:03 AM
4DGS's Avatar
Yea, you won't need to stretch.
The rear might be an issue if you decide to lower it a fair amount but at stock height you won't have an issue. If you do lower it just let the camber takes it's path and you'll clear the fenders fine.
245/35 and 275/30 is my recommendation ad well.
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
mryogi
Aug 14, 2015 07:58 PM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
