need advice on tires size on 19x10.5 +o
Old Aug 8, 2011 | 01:26 PM
Xet's Avatar
Xet
Here is a pic of my setup so you can kinda get an idea
+12 offsets all around, 255/35/19 in the rear with 15mm spacers on. Don't recall the camber, but it was very light. Rolled rear fenders. I am actually probably going to bump up to 265 or 275 next tire set to close a bit more of the gap.
Old Aug 8, 2011 | 01:38 PM
Cabos G35 Coupe's Avatar
whats the whole set up again?.... and thanks for posting it bro
Old Aug 8, 2011 | 03:09 PM
Xet's Avatar
Xet
edited original post.
Old Feb 7, 2014 | 04:35 AM
andywhite2008's Avatar
Cool 285tires
Im running 245/40/r19 front 285/40/r19 rears and i am pretty hellaflush most of the times no spacers, just rolled fenders i got sum fatboys on my bbs grey powder coats, check my pics, love the twilight blue color the most I got lucky just found mine last month and love it. Has a full camber kit, my wheels are very agressive they poke out as you can see wouldnt mind trying to fit 305s on there if i can come across a cheap pair in the atlanta area.
Attached Thumbnails need advice on tires size on 19x10.5 +o-photo-4.jpg   need advice on tires size on 19x10.5 +o-photo-5.jpg   need advice on tires size on 19x10.5 +o-photo-3.jpg
Old Mar 15, 2014 | 06:40 PM
jpez179's Avatar
Originally Posted by irishsig
What springs are u dropped on? 275s should fit.
Just to give you an idea, my rears are 285/35/19 +12 offset.
I'm on Z stechs with the rear spring mount mod (about 1/2" I think) and rolled fenders.
The only time I rub is if I go over a lrg bump doing over 60.
Granted your wheels will be more pushed out than mine but the 275 sidewalls will be lower.
What type of wheel are you running?...they stop making the toyo prox t1r which im running now and i need a replacement tire, Thanks
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
Jnm07
Aug 6, 2015 03:03 AM
Popes
Jul 29, 2015 05:07 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
