Question regarding spacers and studs
I own an 07 G35 sport sedan, and I am planning on purchasing a set of 10mm Ichiba version 1 spacers for my front MRR wheels. Do I need to use the studs that come with the spacers, or can I use the oem studs? Will the oem lugs have enough thread to securely attach the wheels? I dont really want to use the extended lugs...I have no idea how to change them, and directions are not included. TIA
Yes you will have to use the extended studs that come with the spacer. If you don't want to swap our your studs then get a set of Project Kics 10mm spacers with built-in studs.
I suppose you could take your wheel off and see how much room there is to play with,
but it seems better to just get a wheel spacer with the extended studs.
With a 5mm spacer you have enough threads left on the OEM studs to get 3 full turns of the lug nut. I wouldnt run more than that (5mm) with OEM studs. Built in is the way to go like they said.
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
laksjd84
Steering & Suspension
14
Aug 8, 2015 11:47 AM
