Spacers to fit 245/45/18 in front
Old Jul 25, 2011 | 01:05 PM
cmietzner's Avatar
I searched and it seems the only problem people are having, it the tire rubbing on the fender. But I have the opposite problem.
I bought some used rims (5zigen Hyper 5zr) to use for autox. Then without thinking, I bought 4 BFG R1 245/45/18 and had them mounted. Then threw them in the trunk/backseat and went to the race.
This is when I realized that the tire was too wide and the rim didnt have enough offset. The tire is hitting the upper control arm (I think thats what it is) So now I need to find what size spacer I need to make these fit. Does anyone have any idea?
Old Jul 25, 2011 | 09:09 PM
4D05G35's Avatar
What is the width and offset of the wheels?
Old Jul 25, 2011 | 09:15 PM
cmietzner's Avatar
I believe they are 9". How do I figure out the offset?
Old Jul 25, 2011 | 09:41 PM
EL-EE-ES's Avatar
Look on the back of the wheel...they might have a sticker or might be stamped with the offset
Old Jul 25, 2011 | 10:06 PM
4D05G35's Avatar
Either this ^ or you can measure the back spacing.
Take a straight edge to the back of the wheel and measure from the mounting pad to the straight edge. If you have an 8" wide wheel and you measure 5" from the straight edge to the mounting surface your offset is 1" (+25mm).
8" divided by 2 = 4". So if you measure 4" from the straight edge you have a -0- offset.
Works the same on any width of wheel. Divide the width in half (10" wide, would be 5.5") and that gives you the center of the wheel. If you measure more than half the width then your wheels have a positive offset, if you measure less than half then you have a negative offset.
Or you can check online to see if the manufacture lists the offsets and widths.
Old Jul 26, 2011 | 10:48 AM
cmietzner's Avatar
I didnt see anything on the back of the wheels and by the time I got ^ this message I was already in for the night. Here are some pictures... Oh and I didnt realize the size was on the back and I guess I measured wrong. They are only 7.5" wide.... How disappointing...
Old Jul 26, 2011 | 10:52 AM
cmietzner's Avatar
After looking online the offsets for the 7.5" 18's came in 35, 43 and 48. Is that what the 43 means?
Old Jul 26, 2011 | 11:11 AM
4D05G35's Avatar
Yep, ET 43 is the offset.
Old Jul 26, 2011 | 11:14 AM
4D05G35's Avatar
You can put a 15-20mm spacer with no problem.
Old Jul 26, 2011 | 11:51 AM
FlyingMustache's Avatar
I'd go with a 20mm, maybe even a 25mm just depending on how aggressive you want it. It'll look nice with a 25mm though.
Old Jul 26, 2011 | 11:53 AM
cmietzner's Avatar
Awesome. Thanks everyone. Ill post pictures after I get them.
jsimonk
Dec 22, 2023 03:49 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
laksjd84
14
Aug 8, 2015 11:47 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
Kicknshift
18 Inch
Jul 22, 2015 04:13 AM
