Sedan wheel to coupe 18...
Old Dec 11, 2004 | 04:33 PM
subrobo's Avatar
Hi, Season Greeting
I'm wondering if it is possible to swap the coup 18'' to the sedan. My plan is to get my stock sedan 17'' for winter and get another 18'' wheel for the summer so i dont have to change to winter tires everytime. Can anyone give me suggestions to some sexy 18''?? It would be cool if you can provide me some pictures and $$$.
Thanks guys!
Old Dec 12, 2004 | 06:00 PM
subrobo's Avatar
so is it possible to put coupe rims on to sedan?
Old Dec 12, 2004 | 06:10 PM
Britishbloke's Avatar
Pretty sure it's allright. I believe I've seen several members on here with the 18" Coupe wheels on their sedan. Might want too do a search for pics.
Old Dec 12, 2004 | 06:38 PM
VinNYCG's Avatar
G SQUAD
its definitely possible as there are a few members that have done this. As far as what adjustments you may need to make if there are any or anything like that I dunno. But there definitely sedans rollin with coupe 18's
-Vin
Old Dec 12, 2004 | 07:32 PM
Dudefish's Avatar
I know I've seen pics. For some reason it seemed like the car needed lowered by 1/2 or 1" with those wheels though. Not sure why.
Old Dec 13, 2004 | 02:36 AM
subrobo's Avatar
Ic, ill do more search and find out about it. Thanks guys.
Old Dec 13, 2004 | 10:57 AM
jedmonds's Avatar
Yes it will work. I had 18" coupe wheels on my ride, till I got some Piaa Super Rozza's. The front needs to be lowered cos there is a HUGE gap.
Old Dec 13, 2004 | 10:57 PM
subrobo's Avatar
Red face
Even a 18'' wheel on sedan have a huge gap? What about the set up of 19'' aftermarket wheel? will it rube when turn? or 18'' is fine without lower the ride? Cause i really dont wanna lower my ride~
Old Dec 14, 2004 | 04:08 PM
VinNYCG's Avatar
G SQUAD
when you add bigger rims you actually end up raising the height of the car. Therefore if you lower the car you should be able to have the car sit at a height that is just right!
-Vin
Old Dec 14, 2004 | 04:29 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
-Vin
Actually the car height should stay the same if you do a
plus1 or plus2 size change.
Basical the wheel DIA is larger & the tire profile is lower.
The total DIA is close to the same.
Basic rule of thumb is to stay within 3% differential from stock.
FWIW, I try to stay arround 2%.
The gap or ride height is modified by suspension changes
Old Dec 14, 2004 | 07:15 PM
sen_jen's Avatar
Meatshake Enterprise
-Vin
i never really thought of that!! lol. so true.
Old Dec 15, 2004 | 07:34 AM
subrobo's Avatar
-Vin
I'm actually considering 19'' HPracing evo on my sedan...But i really dont want my ride lower then now because i need to get down to underground parkin...Which spring do you suggest for changing from 17'' stock to 19''?
Old Dec 15, 2004 | 10:31 AM
InTgr8r's Avatar
Guys, the total DIA (size) does NOT change.
The bigger the wheel, the smaller the tire profile.
Checkout the pic for a simplified example.
Old Dec 15, 2004 | 05:31 PM
subrobo's Avatar
thanks for the info Intgr8r, this really clears some of confusion up. BTW can you explain what "offset" means?
Old Dec 15, 2004 | 05:39 PM
InTgr8r's Avatar
Offset is the distance from the center line of the rim
to the mounting face (hub).
Positive offset = hub to the outside of center line
& the smaller the offset the further the wheel is out to the fender edge.
eg
+35 is more to the outside than +48
Brodys_GCoupe
Nov 7, 2015 08:06 PM
teamghost
Jul 28, 2015 04:52 PM
tiguy99
Jul 26, 2015 01:39 PM
si_driver
Interior
Jul 25, 2015 09:22 AM
