40 an 45 tire difference
Old Oct 9, 2011 | 12:26 PM
G35xcuter's Avatar
i have the stock 18"s on my coupe and the front tires are 225 45 18 and are still in greact contidition. my rears are bald and need to be replaced If i put 245 40 18's on the rrear would it make a big difference? Im asking because my friend has a set of 245 40 18's he will give me for dirt cheap. will it make my rear sag down more that the front of the car?
Old Oct 9, 2011 | 01:00 PM
Xet's Avatar
Xet
use the tire size calculator to give you your answers
Old Oct 9, 2011 | 11:42 PM
4D05G35's Avatar
This should answer your questions.
http://www.1010tires.com/TireSizeCal...?action=submit
Old Oct 10, 2011 | 12:38 AM
Dubi2087's Avatar
The 245/40-18 will be too small for the back and will make it look uneven with the front being a 45 series. I would stick with a 45 series in the rear unless you are going to also change the front to a 40 series.
Old Oct 10, 2011 | 07:43 AM
Frankieg35's Avatar
But don't u have to take in consideration that the front is 225 and the rear is 245?? 245 is wider and has a bigger sidewall when u have 45 series front and rear..
Old Oct 10, 2011 | 10:26 AM
4D05G35's Avatar
Thats how the car comes stock. The rear tires are slightly larger than the front.
Old Oct 10, 2011 | 10:43 AM
4DGS's Avatar
I would actually recommend running the 245/40 with the 225/45
You will not have any issues what so ever.
Old Oct 11, 2011 | 04:31 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Using the 40's on the rear will make the front tires taller than the rear. May have VDC issues with that. Best to stick wtih the oem sizes.
Old Oct 11, 2011 | 04:54 PM
2fly4em's Avatar
I blow out my rears a bought some used 245/45/19 and my vdc light come on after a 1/2 of mile..my front is 22/40/19...so like neal@tirerack said stick to oem
Old Oct 11, 2011 | 05:16 PM
4D05G35's Avatar
That would be because your rear tires were 1.6" taller than the front tires, or 5.8% taller.
You want to keep the diameter difference less than 3% to keep VDC happy
Old Oct 11, 2011 | 06:41 PM
MikeDG's Avatar
I run 225/45/18 fronts on a 8.5 wide rim and 245/40/18 on a 9.5 wide rear with no vdc issues.
Old Oct 13, 2011 | 09:38 AM
G35xcuter's Avatar
thank you for the input guys. i went with the stock size.
vitamin.v
Nov 7, 2019 06:10 PM
bjo16
Aug 4, 2015 09:52 AM
itschuckster
Jul 25, 2015 08:07 AM
realtalk21
Jul 20, 2015 09:07 AM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
