Installed Hotchkis - now knocking noise - HELP
on
OK - just to wrap up this thread with a resolution. Here's what I did to fix the problem: I jacked up the car and inspected the endlinks. They were all in good shape except the front passenger-side endlink bolt was *very* loose. This explained at least part of the problem. Then I disconnected the swaybar brackets, pulled off the bushings, and greased them very liberally with water resistent, lithium grease. I mean I piled that stuff on - on the inside of the bushing, on the sides of the bushing where they contact the collars, and between the bushing and the bracket. After re-assembling everything, I went for a test drive and all is now good. Now more knocking, a very firm solid feel.
In my opinion, the grease provided with the Hotchkis kit is not enough to do the job adequately. Whatever grease you decide to use - lay it on thick!!! Also, make sure you double check all your bolts. I was about 2 turns away from the endlink bolt falling out!
Z1Motorsports
Suspension-Vendor
56
05-31-2020 01:56 PM
Thaaa_king
07-18-2015 05:56 PM
