Help Me Out Lowered G's With Teins..
Old Jan 20, 2005 | 09:48 PM
Sponger's Avatar
6MT Brembo Coupe
Originally Posted by g_man35
They were able to put the alignment back into specs????
I'm no alignment expert, but based on the print-outs they gave me, my fronts (-1.4) were out of the specified range of -1.3 to .3. Rears (-1.6) were in the specified range of -2.0 to -1.0. The tech also gave me an alignment lesson as toe and camber inversely affect each other (more toe means less camber, and vice versa).
Old Jan 21, 2005 | 07:10 PM
g_man35's Avatar
so have the springs settled?? thats damn good alignment and pretty much within specs!!
I think Im gonna have to swap out the htech g's for the z's!!!
Old Jan 21, 2005 | 10:27 PM
Sponger's Avatar
6MT Brembo Coupe
g man35, I've driven about 200 miles so I think they've settled. IMO, stick with your G HTechs or go with another spring that'll lower the back of your car more. Your goal was to lower the back of your G more and the Z springs will end up being about the same.
Old Jan 23, 2005 | 07:07 PM
Sponger's Avatar
6MT Brembo Coupe
Originally Posted by Sponger
Oh yeah, got the springs from mynismo.com for $165.00 shipped to my door (add tax if you're in Cali). They matched another vendors price for me.
I've gotten a few PM's about this...
Send an e-mail to Tony or Jason at parts@perfnissan.com. Ask them to match another vendors price of $165.00 shipped (350zonlinestore.com). I went thru Tony because of their good reputation with the Z guys. Awesome service as I got my springs the very next day
Old Jan 24, 2005 | 11:48 AM
Redline6MT's Avatar
Thanks for the info. I just sent an inquiry to Jason a few minutes ago.
Thanks to this thread, I am pulling the trigger on the 350Z H-techs. Camber issues seems to vary by car, so I will just have to keep my fingers crossed.
Old Feb 1, 2005 | 05:34 PM
g_man35's Avatar
I have more than 2 fingers with the G's H-techs. Back is not lowered at all! Anyone else have some infor on these z's htechs.. Has it settled more now SPONGER?? T
Old Feb 2, 2005 | 12:54 AM
Sponger's Avatar
6MT Brembo Coupe
g man, I've only driven the car about 300 miles since getting the springs and it has settled a tad more (measured using a yardstick). Like I said, the Z Htechs probably won't suit your needs if you're look for more of a drop compared to the G Htechs.
Old Feb 2, 2005 | 12:56 AM
Sponger's Avatar
6MT Brembo Coupe
BTW, Keith N got his Z springs installed and he likes them. The alignment was in spec.
Old Mar 8, 2005 | 01:50 AM
SolidForce's Avatar
what size rim/tire are you guys running? Any rubbing and, truely, is the ride really affected? I want to really keep the stock feel.
-SF
Old Mar 8, 2005 | 02:45 AM
Keith N's Avatar
SolidForce,
As Sponger mentioned, I have had the Tein H-Techs for the 350Z for 2 months now. I'm very pleased with the drop, ride and performance. The ride with the H-Techs was very close to stock before I put the Hotchkis Sway Bars on. The Sways stiffened up the ride, but the car really hugs the road now. The alignment came in just within specs. You can check out pics of my Red G35C in the Wheel & Tire section - Red G35 Rims page #2.
Old Mar 8, 2005 | 03:33 AM
CreativeAutoworks's Avatar
We have our H tech's listed at 160.60 shipped to your door, have them in stock as well. Let us know.
Old Mar 8, 2005 | 09:37 AM
Sponger's Avatar
6MT Brembo Coupe
-SF
The ride will be slightly stiffer, especially over bumps. With the advertised springs rates and drop for these springs, I was somewhat surprised with the stiffness.
CreativeAutoworks, $160 shipped for these springs is a good deal!
Old Mar 8, 2005 | 11:55 AM
Gsedan35's Avatar
As a reminder, the whole idea running a Z Tein H-tech spring on the G35 is that it wraps up a mild drop that should allow you to avoid expensive aftermarket camber correction and equally important for those that want to maintain how the car's balance, the Z H-tech's do NOT have the weaker then oem rear spring rates that both G35 Tein lowering springs do. This will matter to those that want to maintain as much of the car's handling mannerism. Weaker rear spring rates move roll stiffness to the front of the car, the car already understeer's, that will add more.
If you find that the Z H-tech's don't lower the rear of the car as much as you like, their is a way to change that, vs going to a different spring with less performance to offer. https://g35driver.com/forums/wheels-tires/44778-5-drop-rear-without-springs.html
A even better spring then the Z H-tech's for those wanting performance first and formost, would be the RSR down spring ment for the Z. BUT, at around a 1.1" drop. The odd's of needing whole car camber correction increases.
As we look to aftermarket springs, especially one's that increase spring stiffness over oem rates, we owe it to ourself's to make certain that we are open to the idea that maybe, just maybe the oem shocks aren't quite going to cut it. I think a number of owner's exist that simply don't have the experience or knowledge to sense that the oem shocks might not be providing the best control for their ride, not a put down, would just like to see owners get the most out of their cars. Frankly, every G35 even with oem springs would be improved with aftermarket shocks like Koni's or Tokico D-specs.
Tein S-tech 350z (fronts are progressive, rears are linear)
Spring rates in lbs 386/402
Stiffer then oem by F+23% R+16%
Transfers +7% roll stiffness to front
Lowers G35 coupe 1.2"/1.1"
Lowers G35 sedan 1.7"/1.6"
Tein H-tech 350z (fronts are progressive, rears are linear)
Spring rates in lbs 358/375
Stiffer then oem by F+14% R+11%
Transfers +3% roll stiffness to front
Lower's G35 coupe by .8"/.7"
Lower's G35 sedan by 1.3"/1.2"
Tein H-tech G35 coupe & sedan(fronts are progressive, rears are linear)
Spring rates in lbs 324/260
Stiffer/softer then oem by F+ 5% R-22%
Transfers +27% roll stiffness to front
Tein S-tech G35 coupe & sedan (fronts are progressive, rears are linear)
Spring rates in lbs 358/274
Stiffer/softer then oem by R+14% R-18%
Transfers +32% roll stiffness to front
RSR 350Z springs
Spring rates in lbs 345/417
Stiffer then oem by F+10% R+22%
Transfers +12% roll stiffness to rear
Lower's G35 coupe by 1.1"/1,1"
Lower's G35 sedan by 1.6"/1.6"
Old Mar 8, 2005 | 12:24 PM
z_with_back_seat's Avatar
Question Suspension Newbie ??
Now for those of us looking for a little more performance out of this, should we concider new shocks right away like Tokico D-Spec?
I have a little money left over after ordering rims/tires but I do not want to spend it foolishly or have to spend even more to get more camber corrections $$ after doing this. The wheels are on the way 18x9 +18 front, 18x10 +22 in rear, 245/275/40 combo.
For those experts out there can you let me know??
Do I just do the springs (Z H-Tech) or add the shocks (Tokico D-Spec)?
If I add the shocks, will the drop increase more?
Will I need to get camber correctioneither way?
Will I rub / need to roll fenders?
THANKS!!!!
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
