well thats an interesting camber wear...?
Old Jun 12, 2012 | 10:13 PM
2one8's Avatar
anyone ever seen this before? I know I need an rear alignment but this is from the fronts, but this is only a couple weeks since the drop, and only something like 1.7deg negative in the front. I was informed that everything else up front checked out fine for front alignment...?
Funny thing is, this doesn't go all the way around the circumference of the tire, it's only about half the tire, maybe a little more. The area of the tire that isnt like this looks fine. Nothing is rubbing or cutting into the tire.
Old Jun 12, 2012 | 10:19 PM
My Key's Avatar
Had that happen to me. Shop told me it was a faulty tire.something about tread separation and bumps in the road
Old Jun 13, 2012 | 01:48 PM
VMRWheels's Avatar
Interesting wear indeed, but I don't think that's entirely due to camber. I've had similar wear in the past though.
Old Jun 13, 2012 | 01:59 PM
dofu's Avatar
20 Year Member
Done any hard braking lately?
Old Jun 13, 2012 | 02:19 PM
My Key's Avatar
https://g35driver.com/forums/g35-cou...uspension.html
like i mentioned before. the two shops i went to said i had a faulty tire
Old Jun 13, 2012 | 02:24 PM
dofu's Avatar
20 Year Member
Ah, I see what we're looking at now!
Old Jun 13, 2012 | 02:38 PM
JaE35's Avatar
Moderator
G35 Sedan
i had wear similar to this on a tire i just pulled off...sucks but i know the reason for mine and its a blown inner tie rod...it will not hold toe alignment specs until its replaced
Old Jun 14, 2012 | 06:38 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Eesh! Crazy stuff.
Old Jun 15, 2012 | 01:28 AM
2one8's Avatar
gettin new tires on Monday. Unfortunately i cant get into the shop until after I get tires to have everything checked out again. The crappy part is i have to pull the bumper, fenders, and side skirts to bring it in because its too low to fit on any alignment racks and you cant adjust the camber in the front with fenders on unless you drop the struts
Old Jun 15, 2012 | 01:31 AM
g35pillow's Avatar
Your camber should not do that to your tire. That look like its from your TOE specs or something is wrong with your suspension
Old Jun 15, 2012 | 02:45 AM
VMRWheels's Avatar
+1
When I had similar wear in the past it was always due to my toe being out of spec.
Old Jun 15, 2012 | 10:55 AM
MN-G-Fever's Avatar
I would guess your toe is pointed inward... Camber doesn't really wear done your tires that much, especially in such little time... What is your toe at?
Old Jun 15, 2012 | 01:49 PM
CLEANBS's Avatar
nt555>>>>>
Old Jun 15, 2012 | 06:22 PM
2one8's Avatar
I'm not saying that the camber did that, I'm saying they cant adjust anything for camber without the fenders off. I wanted to bring the camber in just a touch when i get it aligned again. I'm just confused as to why its only half the circumference of the tire that is like that? Hoping it was just a faulty tire.
I had it in for an alignment right after I installed the coils and they said the front was in spec minus the camber being negative. Shops here arent used to anyone asking to run negative camber so they get rather confused when you want specific angles. I wont be going back to the same place though, not only do they apparently suck at alignments, but they also neglected to tell me the car wont fit on their rack without scraping really bad, and they just forced it on and got it hung up in the middle...
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
MrIP35
Audio/Video/Electronics
Nov 8, 2015 10:47 AM
