Help me on this setup!
Old Jan 25, 2005 | 01:56 AM
leatherSOUL's Avatar
Holy cow! The more I read, the more confused I get. Can you guys help me out?
I'm looking for a staggered setup on a 2005 Sedan, 18x8/18x9 or 18x8.5/18x9.5. What offset will give me maximum lip without any fitting problems? I'm planning on getting the TEIN basic coilovers.
Thanks so much for the help!
Old Jan 26, 2005 | 01:10 AM
Gsedan35's Avatar
First thing that comes to mind it to warn you that Basics on the sedan will require a investment in front adjustable control arms, like $389 Cusco arms. And the rear will require $240 SPC camber arms/elongated toe bolts to bring the alignment back into spec. This is because of how low they drop the sedan.
I can't help you on maximum rim lips, simply because it's not something that I look for, but I can get you the offset ranges. If you REDUCE offset's to get lip depth, this will mean tire width's will have to go down.
IMO, these car deserve at least a 245 tire in the front.
On a 18x8 rim in the front, with a 225 tire, you can do a 30mm to 45mm offset
On a 18x8 rim in the front, with a 245 tire, you can do 35mm up to 45mm offset.
On a 18x9 rim in the rear, with a 265/40 tire, with a 43mm to 55mm offset
On a 18x9 rim in the rear, with a 245 tire, you can do a 38mm offset
On a 18x5 rim in the front, with a 245 or 255 tire, you can do a 38mm/40mm offset
On a 18x9.5 rim in the rear, with a 275 tire, you can do 45mm/55mm offset
If you must do staggered widths, keep the front to rear rolling diameter as close as possible, I would not exceed 1% front to rear differance.
Old Jan 26, 2005 | 01:13 AM
Thank you so much. That really helps me a lot. About the Basics, would it be better to just get springs like S-Techs or H-Techs if I'm only looking to reduce gap, not for performance?
Old Jan 26, 2005 | 04:44 AM
sen_jen's Avatar
Meatshake Enterprise
S Tech's would be fine. May want to consider the Tanabe springs too. They lower the vehicle just a tad bit more than S Tech's.
Old Jan 26, 2005 | 12:26 PM
jdbinspired's Avatar
If you want to reduce gap... Just get the springs and I can help you out in giving you that custom look... If you seen my G around it will probably help you in your decision...
Old Jan 26, 2005 | 12:37 PM
sen_jen's Avatar
^ hmm....housing style mang!! j/p!
Old Jan 26, 2005 | 02:08 PM
I didn't want to go quite as low as the S-Techs for the sedan. People have been saying the H-Techs for the 350Z work perfectly. Would that work too?
Old Jan 26, 2005 | 02:34 PM
sen_jen's Avatar
^ yes, they would.
Old Jan 26, 2005 | 02:49 PM
Trik69's Avatar
Why go with the H-Techs for the z and the the g?
Thanks,
John
Marlin84
Apr 1, 2020 12:52 PM
DRG35R
Jan 31, 2016 07:14 AM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
AL8782
Oct 3, 2015 10:26 AM
JustinMKN1
Sep 18, 2015 03:40 PM
