245s n 285s
Old Jan 28, 2005 | 09:01 AM
aam6906's Avatar
245s n 285s
Hey, i have G35x and i wanna get 19" wheels, can i get a 285 in the back? so the rim has about a 3 inch lip?.........n i want 245s in the front........just wondering if this is possible......i would like the rims to be something like 19x9.5 for the rears and 19x8 or 8.5 in the front.......would i be able to go with that setup?
Old Jan 28, 2005 | 09:06 AM
jmaldonado's Avatar
That is the setup Im running on my Z right now 19x8.5 in the front and 19X9.5 in the back with 245/35's and 285/35's. So far no problems...feels good.
Old Jan 28, 2005 | 09:45 AM
Boon's Avatar
Dont think that would work real well in the rear (285) on a sedan. I think 275 is as wide as you want to go on a sedan, and then the offset better be right.
Old Jan 28, 2005 | 09:57 AM
aam6906's Avatar
yea, i want sure if that was too wide or not......anyone have a sedan with 285s on the rear?
Old Jan 28, 2005 | 09:58 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
I'm pretty sure 285 won't work.
Also keep in mind that you could end up with problems with the ATTESA AWD if you don't match front and rear DIA.
Old Jan 28, 2005 | 10:06 AM
aam6906's Avatar
o well 275s it is i guess........what u mean i could have problems with the AWD?
Old Jan 28, 2005 | 11:23 AM
InTgr8r's Avatar
If the front & back are different diameters,(often the case with staggered setup)
the AWD will see this as slip & shift the drive ratios.
Remember the ATTESA works as a RWD & will bring in drive
to the front as required.
If you end up with a smaller DIA in the back, then you could end up with the ATTESA applying drive to the front all the time.
The big question is just how sensitive is the logic algorithm.
This is really a tech question.
JMO, but I would inquire further before making a wheel & tire purchase
Old Jan 28, 2005 | 12:06 PM
Boon's Avatar
Strongly agree there....especially with the AWD model.
Old Jan 28, 2005 | 12:09 PM
jdbinspired's Avatar
I would go with the 275 for the rear... 285 are going to look too big...
Old Jan 28, 2005 | 12:41 PM
aam6906's Avatar
yea ill prolly just got with 275s in the rear and 245s in the front
lacartus
May 27, 2005 04:09 PM
NORCALSTI
Feb 21, 2005 03:49 AM
maxpower
Dec 30, 2004 09:17 AM
Meatshackle
Feb 1, 2004 02:53 AM
myG35ZX
Jan 20, 2004 10:45 PM
