Lowering on 20's NEED ADVICE!!
hey guys,
Just threw on some 20 x 9 front (245/35/20) and 20 x 10.5 rears (275/30/20) and now im looking to lower the car. I know that you need to cut rear and front fender wells right? And what springs do you guys suggest for this kind of setup where big dips or bumps wont let the body hit the tires tread? Looks like im searching for a spring thats pretty stiff so the car doesnt bounce. From your guys opinions in the past, looks like tein s-tech is right for me.. Anyone have a similar set up to share with me using words or pics? Thanks!
I,m running 255-35-20 in front
285-30-20 in the back
on 1.1 drop
the front rubs only little bit on driveways
inside egde of fender
but no rubbing in back
rides great
on 1.1 drop
rides great
you're not going to rub at all - so I wouldn't worry about it - running a stretched 275/30 on a 10.5" wheel is going to make all your lowering questions go away - the s-techs for the 350Z would be a great spring for you (my suggestion)
Paragham
Sep 15, 2015 12:04 AM
