25mm+ slip on spacers
Old Dec 5, 2014 | 05:17 PM
  #31
2one8's Avatar
if you want strength with spacers, run ARP studs in the hubs, and then run another set of ARP studs in the spacer. Gets spendy, but best bet when it comes to larger spacers. I've been running 30mm rears on road course for a few years now, no problems. Only issue you will run into is extended studs cant be installed in the rear unless you remove the hubs, not enough clearance.
And you'll burn up hub bearings faster running large spacers.
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
vamarris
Sep 26, 2015 12:56 PM
