Please help
Old Mar 9, 2016 | 08:57 PM
portugueseG35's Avatar
Please help
So I'm looking for wheels for my sedan and looking at getting Yoshihara design Champion wheels in the rear i want to get 18X10 but I'm not sure what offset to get I'm thinking +25 I want the wheel flush and not too much camber and i dont want to add spacers. could someone please help thanks
Old Mar 9, 2016 | 11:34 PM
Conissah's Avatar
Here you go.
Old Mar 9, 2016 | 11:52 PM
Yea it's called I googled didn't find the answer so I asked but thanks for the help
Old Mar 9, 2016 | 11:57 PM
hurleyguys's Avatar
check out this site.
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
plug your numbers in and see what you get.
Old Mar 10, 2016 | 12:59 AM
Conissah's Avatar
Go to my initial response and click the 6mt link, scroll to post 10 and read.
Or I'll quote it: "18x9.5 +20 will stick out past the fenders by about 10mm on your '05 sedan. My G coupe 18x8 +30's are pretty flush with the fenders."
So if the 9.5 + 20 will stick out 10mm, then the 10 + 25 will stick out ~2mm more.
Old Mar 10, 2016 | 07:36 AM
Please help
Ok so I might have to go +35 and if need be I will have to get a spacer thanks Connisah
Old Mar 10, 2016 | 11:14 PM
Conissah's Avatar
If the offset is too high then they will hit the struts. Look for a similar setup and base the wheels you are going to buy off of their specs that will be known to fit.
Old Mar 12, 2016 | 12:33 PM
I'm pretty sure +35 will clear the strut fine I've read about people putting +40 on the sedan and clear the strut
Genthusiast35
Mar 24, 2016 02:35 PM
Tylko Kazik
Mar 10, 2016 08:53 AM
Alec1278
Mar 4, 2016 10:53 AM
slicrick
Lighting
Mar 3, 2016 08:48 PM
