NEW HYPERBLACk PIAA's Black Coupe[B]NEED GAP ADVICE[/B]
Old Apr 5, 2005 | 12:06 AM
BulletproofG35's Avatar
Even though you are changing the wheel size from 18" to 19" you should always aim at keeping the same stock tire height within 1-2%. This is crucial to preserving the speedometer reading and gear ratio.
If you want to lower for visual purposes only, a nice set of springs will be just fine.
Old Apr 5, 2005 | 12:24 AM
Originally Posted by xstarpro
Thanks Bulletproof
Here are the sizes Im running..
TID BIT: Although overall diameter apprears slightly smaller than my stock set up...To my suprise my speedometer is dead on when compared to GPS...
NEW
Front TIRES 245/35/19
Rear TIRES 275/30/19
OLD
Front TIRES 225/40/18
Rear TIRES 245/40/18
You actually went from 25.1" to 25.8" on the fronts and 25.7" to 25.5" on the rears, so your tire size is fine. You could have also gone with 275/35/19 on the rears to give you a little more sidewall.
Go ahead and look for some springs or coilovers to close that gap.
Old Apr 5, 2005 | 02:23 AM
xkoraznboix's Avatar
20 Year Member
love ur car!!
Old Apr 5, 2005 | 02:27 AM
GYAL8R's Avatar
Cali Event Coordinator
BASE ACURA TLX NOW WANT A G35 AGAIN THOUGH
Where did you order the PIAA's?
I've been shopping eveywhere for them.
Been " " $3,997 / $3900.00 / $2,000 for just the rims etc. - 19 x 8 front / 19 x 10 rear -
Where did you get yours from and how much!
Please advise...I love those rims...GREAT CHOICE...!!!
Old Apr 5, 2005 | 02:48 AM
skeleton_cru's Avatar
Sedan
If you are lowering the car strictly for aesthetics, then install a good set of springs. They are considerably less expensive then coilovers.
Old Apr 6, 2005 | 03:09 AM
Sedan
Thanks Skeleton-
What do you recommend in terms of springs?
Are any better than others? Ive read many conflicting reports (very confusing).
Also, many have reported alignment problems and ride quality sacrifice on all the products Ive looked at? Are these complaints isolated-due to improper installation-or competing vendors slamming each other--or a little of all--Im really in the dark here? Cost is not the major factor..I just want to do it right the first time..
Im looking for a similar if not identical ride to stock with no alignment issues and a lower profile 1-2 inches to please the eye--remove the gap...you know what I mean..Please advise if these goals are unreasonable..
THANKS FOR ANY INPUT!!
I have not heard anything bad about Tein springs. Take a look at your options there. Some people love thier Eibachs, but I've heard some complaints as well. There are more options, I just can't think of them right now.
As far as alignment goes, the more you lower your car the worse the alignment issues. Any more than a inch and you will probably have alignment numbers out of spec.
I lowered my sedan 1.5" and the alignment shop was able to get everything (caster, toe) into spec except my camber in the front. I am -0.1 degrees on the left and -0.5 degrees on the right. After 5k miles on my S-03's I can see slightly more wear on the inside edges of the front tires. It's not that severe, but I will probably end up getting a set of camber adjustable a-arms for the front.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
itschuckster
Jul 25, 2015 08:07 AM
laksjd84
Jul 24, 2015 05:12 PM
laksjd84
Accessories
Jul 24, 2015 12:37 PM
