problems with suspension
Old May 19, 2005 | 12:39 AM
AxisG35's Avatar
Hey guys, im trying to install my tein s-tech springs twice now and we cant get the damn BIG *** bolt off behind the springs....has anyone done this install themselves, and since every damn bolt on the infiniti's like to rust 2 days after they leave the factory, how am i supposed to get the things off?? I just cant budge these things...any help?? Thanks
Old May 19, 2005 | 01:24 AM
kenchan's Avatar
Are you talking about the rear?
Are you using a breaker bar? You should feel how tight the WRX suspension are...
hehehe.. compared to that car, the G was pretty easy.
Old May 19, 2005 | 01:54 AM
myGspot's Avatar
yes which bolt youtalking about. ??
WRX is on tight. 140 ft lbs i nearly snaped my breaker bar doing my buddies suspension.
Got air tools?
Old May 20, 2005 | 03:52 PM
AxisG35's Avatar
Used breaker bar and air tools and still could not get the thing off.......its the HUGE bolt on the bottom of the sub frame connected to one of the suspension arms....but the bolt is like the biggest bold on there and we just cant get the stupid thing loose!!!!!
Old May 20, 2005 | 04:03 PM
myGspot's Avatar
how old is your car? Could be slightly rusted on there.
go buy stuff called PB BUSTER. spray it on and spray it some more. then try removing it.
Old May 20, 2005 | 05:00 PM
AxisG35's Avatar
Its an 04 with like 6k miles on it.....dosnt look rusted but i have that stuff and i sprayed it on there and still nothing......!!!!!! its probably the biggest pain in the *** ever lol!
Old May 20, 2005 | 10:20 PM
kenchan's Avatar
front or rear?
Old May 21, 2005 | 02:18 AM
AxisG35's Avatar
front
Old May 21, 2005 | 07:57 PM
kenchan's Avatar
You don't need to remove the lower control arm to get to the strut.
After you disconnect the front endlink, undo the cotter pin and nut you see at the
tip of the upper A arm, collapse the A-arm and knuckle, compress the spring
a little bit while it's on the car and just pull out the strut. It's pretty easy.
reverse when you're ready to mount the strut back onto the car. goodluck
snic09
Nov 8, 2017 01:46 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
TreeFiddy
Aug 10, 2015 06:50 PM
Fireman07603
Aug 9, 2015 06:00 PM
atk08
Jul 30, 2015 03:12 PM
