I have a little toe/camber in the front and i have 18k on my pilot sports. When im rollin, the noise from the tires is simply UNBEARABLE. I cannot even talk on my cell phone, its so loud. Does anyone know if this is due to my camber/toe or tire wear? There seems to be still an adequate amount of tread left, so im betting its from the camber/toe. Any thoughts?
Any cheap solutions (i.e. cheap front camber kits)?
edit: To be more specific, the noise sounds like something keeps hitting when the tires roll. You hear this Woosh..woosh...woosh.. and it gets more frequent as the tire revolutions increase. Hard to explain...
wheel bearings?
If it's your tires you can't really fix it now, it's already worn that way.
You might have too much toe-in. After replacing your tires, run an alignment.
Check your tire pressure. If it's too high it will cause road noice. Around 37 -38 PSI should be ok. Otherwise, it could be the bearings like someone said before. Unlikely but possible.
yea i took it in today to get the tire pressure checked since the light was on, and the guy said i need new tires really soon and my camber/toe on the front is contributing to the noise as well. Arggg....so i have to buy a front camber kit and new tires!!!
What is the cheapest front camber kit out there and who sells it????
Where can i get new tires for cheap (stock 18s)??
Keep in mind im a poor college student!
Originally Posted by Omar
yea i took it in today to get the tire pressure checked since the light was on, and the guy said i need new tires really soon and my camber/toe on the front is contributing to the noise as well. Arggg....so i have to buy a front camber kit and new tires!!! What is the cheapest front camber kit out there and who sells it????
Kinetix Upper A Arms (Get the new version) $350 shipped--Try ebay
sounds like u need new tires... near bald tires have those noises...
18k on stock pilot is near the limit already. get new tires !!
