tein S-Tech springs
tein S-Tech springs
hey does anyone have these and if so do they have any problems with them?
does the car bottom out when u go over speed bumps or driveways or anything?
anyways any help is great thanx
Matt
Matt
I have then, it all depends on what you have on body wise as well.
With the stock components and splash guards you may scrape on certain speed bumps and driveways. In time you learn to A. avoid them or B. go over at an angle. Also, if you have the OEM front lip that will sometimes rub on a steep decline. 9/10 though its mostly the black plastic piece under the car that rubs.
You just have to be a little more cautious once they are on.
Hope this helps.
Hope this helps.
I have them and they are great. The car is a little more responsive and a little stiffer but not much. Also, it gets rid of the wheel well gaps.
Every thing Coupin said is the same here as well, Especially if you have a kit on your car, go on the angle. LOL. When i put my 20's on the car went close to the factory ride hight again, but really filled in the wheel wells nicely.
My opinon great spring set, and a good bang for the buck.
thanx alot guys, ya i got em for 170 canadian
but ya im gonna put em on soon my car is completely stock right now but im gonna put 20s on it soon
so is there any way to take of the splash guard under the front bumper? and if so will this help?
thanx again
thanx again
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
