To lower or not to lower?!
Old Jul 19, 2005 | 06:56 AM
amz11's Avatar
...That is the question?
I like the "simmetrical spacing" between the tire and wheel well line. Not sure if Eibachs will spoil that or not. Thoughts?
Attached Thumbnails To lower or not to lower?!-nushooz2.jpg   To lower or not to lower?!-nushooz3.jpg
Old Jul 19, 2005 | 07:25 AM
Benj's Avatar
Just dropping it 3/4 to 1" makes it look even better. Just save all the stock stuff in case you want to go back.
Old Jul 19, 2005 | 11:18 AM
socalsean's Avatar
You'll love it lowered Just get a set of springs that lower the car just a bit. There are many different choices with different amounts of drop.
sean
Old Jul 19, 2005 | 11:45 AM
kenchan's Avatar
From a dressup standpoint the ride height is too high. Target it to get
wheel gap that's 1/2 to 3/4 of the tire sidewall thickness. If your offset is
conservative you can go with 3/4, but if aggressive like yours, you'll need
to consider 1/2. just my honest opinion.
Read the many posts we wrote before choosing your springs so you know
what to expect.
Old Jul 19, 2005 | 11:21 PM
JCatapano27's Avatar
it is a must to lower the car, just did mine and i love the way it looks...
Old Jul 19, 2005 | 11:26 PM
big daddy d's Avatar
Originally Posted by kenchan
Target it to get wheel gap that's 1/2 to 3/4 of the tire sidewall thickness. If your offset is conservative you can go with 3/4, but if aggressive like yours, you'll need to consider 1/2.
Just went out to look at my own car and I must say that was a very helpful and insightful post Kenchan. Thank you.
Old Jul 20, 2005 | 12:54 AM
HardDriver's Avatar
Awesome, your car is EXACTLY like mine, only 6MT and in silver! Good taste!
Old Jul 20, 2005 | 10:56 AM
amz11's Avatar
My only issue is that now there's about a 2" gap simmetrically around the wheel. If I lower it the top of the wheel will be 1". As you move around to the 90 degree and 270 degree spot on the wheel the gap will still be 2". Make sense?
Old Jul 20, 2005 | 11:02 AM
GT-Ron's Avatar
While I think lowering definately gives a sleeker appearance, I just can't do it this time around. The OEM height looks fine, IMO, and I'd rather have the ground clearance and suspension travel. The only way I'll lower is if I end up getting the Nismo S-Tune shocks/springs, but the lowering will be a side-effect of that package, not the priority in getting it.
Old Jul 20, 2005 | 01:45 PM
kenchan's Avatar
yep... so?
kenchan's Avatar
no prob. Just my rule of thumb.
Old Jul 20, 2005 | 06:25 PM
axiochris's Avatar
not to be a jacka$$..
but dont lower your car if you are over 30.
Old Jul 20, 2005 | 08:00 PM
Derzigster's Avatar
I was wondering if the Sport tuned suspension on the 05's sits lower than the regular stock suspension?
Old Jul 20, 2005 | 08:35 PM
papagz's Avatar
Must Lower
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
