Tire size options for OEM 19s?
Old Oct 6, 2005 | 08:31 PM
RDaneel's Avatar
Hey -
I tried some searches and couldn't find this out, any help would be appreciated! I'm interested in figuring out what the popular tire size choices are for the 19" stock rims on '05 coupes. How much different is it safe/smart to go? I want to keep the sizes right for VDC and ABS purposes, of course, but I would love to have flexibility so I don't have to stick ONLy with 225/40 and 245/40...
Thanks!
Old Oct 8, 2005 | 10:20 AM
RDaneel's Avatar
btt
Old Oct 8, 2005 | 03:18 PM
g35doc's Avatar
I'm going with 245/35/19 front 245/40/19 rear. Much more tires to choose from and maintains the correct diameters.
Old Oct 13, 2005 | 05:57 PM
RDaneel's Avatar
245/35 in the front looks close to stock - speedo would be about 1.3% fast, but that's pretty close to spec. Is 245 too wide for the stock rims, and does this mean that the staggered setup the VDC is expecting is off? I'm not criticizing your choice, just trying to learn!
Other than the uber-expensive PS2, there don't seem to be many great options in our stock sizes...
Old Oct 14, 2005 | 05:50 PM
g35doc's Avatar
8" rims are the narrowest recommended for 245/35. OEM fronts are 19x8 so it'll fit fine. VDC is only concerned with tire diameters so no problem here.
Old Oct 19, 2005 | 03:59 PM
RDaneel's Avatar
doc, if you're going wider in the front, why not go to 255 in the back? Any reason not to?
Thanks again for your advice!
Old Oct 19, 2005 | 04:31 PM
g35doc's Avatar
I personally want "neutral" handling and 245/40/19 is obviously an exact match of the oem diameter. Most important for me though is a lighter tire. That's why I will replace with Toyo T1R (pilot sport ps2's are even lighter but a lot more expensive). 245 is 2 lbs. lighter than 255 for T1R.
255/40/19 is not too far off in size though so I imagine it would be ok. I think several people on this forum actually use that size.
Old Oct 19, 2005 | 04:41 PM
hayaku's Avatar
can you stuff 265s in the rear on the stock OEM 19s? like 265/35/19? probably asking for too much I guess.
Old Oct 19, 2005 | 05:05 PM
g35doc's Avatar
Nope. Need at least a 9" wide wheel.
vitamin.v
Nov 7, 2019 06:10 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
reaper76
Aug 5, 2015 10:13 AM
Popes
Jul 29, 2015 05:07 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
