Eibach Sedan Springs installed on Coupe. Q's...
Old Jul 25, 2003 | 12:22 AM
blk6pd's Avatar
I just put on my 20" Maido GR5 wheels on my Black Coupe. I also have the Eibach Pro kit installed. Now I was told by Vick at Discount Tire in El Monte that he was installing the Eibach Springs made for the Coupe. I specifially waited because he said two months ago that the Coupe springs were not released by Eibach yet. Well I got them installed and they look great. I talked with a friend when I got them installed and he said (this was a month ago) that he had talked with a rep at Eibach and the springs were not released yet. He asked me to tell him the code on the Eibach box. I told him this and it turns out that Vick from Discount Tire in El Monte sold and installed the Sedan Springs. I'm pretty upset, but can anyone here tell me if there really is a big difference between the coupe and the sedan springs? Need some advice on this one.
Old Jul 25, 2003 | 12:31 AM
wreck's Avatar
Running for his life!!
Re: Eibach Sedan Springs installed on Coupe. Q's...
What is your part number. Mine is 6365.140
G35C 6MT / AMG E55
Old Jul 25, 2003 | 12:37 AM
Gsedan35's Avatar
Eibach 350Z spring rates front 296/384 rear 316/421
Eibach G35 sedan front 259/334 rear 359/413
I called awhile back and got the above spring rate info from Eibach. I haven't called them yet to find out the rate info on the coupe springs. Frankly, I doubt they'd be very different from the sedan application, since the Z runs much stiffer valving in it's struts. I'd also want to know the free length of the coupe springs vs the Z springs Hey, on that thought, did they lower the car, around 1" ? You really should call Eibach, and ask them what the coupe spring rates are.
Ivry 6mt sed
Injen CAI, 22" resonator
8X18 Enkei RPM2 45mm
Kumho MX 245/40
350Z springs&struts
Old Jul 25, 2003 | 02:00 AM
blk6pd's Avatar
6363.140 is my part #.
Old Jul 25, 2003 | 02:03 AM
wreck's Avatar
bleh that sucks. I would go back and have them give you the right part and have them install them. What a waste of time. I'm upset for you.
Post some pics or email them to me. I'm curious how it turned out. You back should be lower than mine assuming the springs are the same as the coupe.
G35C 6MT / AMG E55
Old Jul 25, 2003 | 02:19 AM
blk6pd's Avatar
Do you live in the LA area? Just wondering, want to see if there really is a difference? I hate to have my wheels taken off by the people that have to eat the cost of used Eibach Springs.
Old Jul 25, 2003 | 03:40 AM
HGS_G's Avatar
Yeap Blk,
You are lucky, Wreck does live in the L.A. area. You can tell by clicking on his user name. Please keep posting the results as I am in the market for a set of Eibachs also and so am very curious about the difference. Hope this helps and thanks.
Old Jul 25, 2003 | 10:34 AM
Gsedan35's Avatar
blk6pd
DID THE SPRINGS LOWER YOUR CAR?
Ivry 6mt sed
Kumho MX 245/40
350Z springs&struts
Old Jul 25, 2003 | 06:15 PM
Gsedan35's Avatar
Ok, I just called Eibach and they told me you called today and I answered my own question above. The front was lowered nicely, but the rear really wasn't. I also now have the Eibach coupe spring rates. Here's a recap
Eibach 350Z rates front 296/384 rear 316/421
Eback G35 coupe front 229/337 rear 274/463
Check out the much softer initial rates they gave the coupe, looks like a hard play on ride quality. A coupe on sedan eibachs would be more responsive. But I also see why you rear end didn't lower much.
Ivry 6mt sed
Kumho MX 245/40
350Z springs&struts
andresito7
Aug 1, 2015 04:53 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Soumilg
Jul 18, 2015 12:33 PM
Scredeur4
Jul 17, 2015 06:30 AM
