BRAKE PADS WITH LESS DUST??
Old Aug 4, 2003 | 02:44 AM
ramo's Avatar
i have an automatic coupe, and of course you are going to be using your brakes more than the manual coupe even when you are in manumatic mode, but i was wondering if there is a brake pad that dosen't have as much brake dust as these stock do? plus i was wondering if anyone out there has the unorthodox pulleys, are they worth it, if so where did you get them.
Old Aug 4, 2003 | 03:35 AM
Mani's Avatar
Re: BRAKE PADS WITH LESS DUST??
There are some pads specially made for minimal brake dust...EBC Green pads or something like that I think.
Old Aug 4, 2003 | 05:32 AM
rstark's Avatar
You could try Hawk HPS from www.tirerack.com.
-Rick
'03 G35C 6MT Ivory Pearl
Old Aug 4, 2003 | 10:39 AM
bocatrip's Avatar
If you change your brake pads, most likely your dealer will void any warranty work on your brakes.
Old Aug 4, 2003 | 11:05 PM
zorro's Avatar
Bocatrip, I didn't think brakes were under warranty. So, why worry about dealer warranty. Am I missing something?
Old Aug 4, 2003 | 11:12 PM
s2k2sti's Avatar
brakes are a wear and tear item and wont be covered under warranty. same applies to clutches.
Old Aug 4, 2003 | 11:30 PM
gogoG35's Avatar
Sorry.. but what is brake 'dust'?
Old Aug 4, 2003 | 11:39 PM
zorro's Avatar
It's the stuff that ends up making your wheels look dirty. It's been very difficult trying to keep my wheels clean. I'll definitely get something that gives off less brake dust, when it's time to replace my pads.
FDNameBrands's Avatar
It’s that powdery looking stuff that you see on the outside of the rims, it develops from the friction caused between the caliper and the disc brakes.
Old Aug 5, 2003 | 12:15 AM
bocatrip's Avatar
Zorro, What I was referring to was anything at all related to a brake issue, such as calipers, rotors, or any brake failure. The dealer will always try to weasel their way out of any responsibility once they decide you have not used dealer approved parts.
Old Aug 5, 2003 | 04:21 PM
DevL's Avatar
Actually they cant void the warranty becuuse you used a non OEM part for a wear part. There are specific laws and court cases that cover this. As long as the replacement part meets OEM specs you dont have to use the OEM part. I dont feel like finding the laws in question but trust me on this.
Old Aug 6, 2003 | 03:15 AM
ryoken's Avatar
Correct. The only way they can require you to use their specific parts for wear items (brake pads, rotors, oil filters, etc.) is if they make the parts available to you free of charge.
Old Aug 12, 2003 | 02:28 PM
3point5SE_Auto's Avatar
I am having good luck with the Stillen Metal Matrix pads. I am only at 200 miles on them but wheels are still clean. PM me next week and I wll let you know how it is doing
braking is as good or a smidge better, dust is less, and they cost less than stock
should work for non brembo coupes, stillen has part numbers;
Better Life thru Chemistry
Old Aug 12, 2003 | 05:18 PM
Nismoboy's Avatar
you've put 200 miles on your brake pads and your wheels are still clean??? wow pretty amazing
John H.
2003 Infiniti G35 Coupe 5AT-Ivory Pearl-Premium Pkg-Performance Pkg.
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
alinero718
Sep 27, 2015 09:35 PM
vamarris
Sep 26, 2015 12:56 PM
NJ6MT
Sep 10, 2015 08:40 AM
