DIY: Parking Brake Adjustment ('05 6mt sedan)
Old 04-17-2011, 11:59 AM
G35fromTO's Avatar
^ I learned that after taking off the entire arm rest the first time... Sometimes the FSM could use a bit more detail.
Removing just that coin holder makes the adjustment so much easier!
  #32
Old 04-20-2011, 01:20 PM
ajm216's Avatar
Originally Posted by LoSt180
Thanks for this post! I just got a 2006 6MT Coupe and have to pull the handle all the way up (9-10 clicks) to get any kind of grip.
I'm not sure if this works for earlier years, but I wanted to point out that you don't have to remove all those trim pieces to access the e-brake nut. There is a felt coin holder that pops right off, then pull up on handle and you can get a deep socket on there.
Here's a picture of the part I'm talking about, hopefully this makes it easier for some people:
I just picked up my 2006 6MT yesterday and my e-brake handle is like a slot machine lever same (9-10) clicks. I'll be doing this fix later today.
fais (09-29-2016)
  #33
Old 04-20-2011, 11:50 PM
ajm216's Avatar
Removed the plastic coin holder
Used a 10mm long socket with an extension to tighten the nut to the point where I could wiggle the nut with my finger slightly when the hand brake is in the off (down) position.
Replaced plastic coin holder
The pull is now about 1/2 of what it was and its a firm grip.
I took all of about 5min to do
Thanks!!!!
  #34
Old 04-21-2011, 06:47 AM
LoSt180's Avatar
^^^make sure you follow up and adjust the brakes also. One side on mine took noticeably more turns to tighten up.
  #35
Old 09-19-2011, 01:59 PM
riotousone's Avatar
floor e brake
Is there a DIY for the e brakes that are on the floor, next to the pedals?
  #36
Old 11-30-2011, 07:58 PM
krazzyborri's Avatar
Excellent write-up!! Adjusted my parking brake in no time!!
  #37
Old 06-18-2012, 05:22 PM
RCL's Avatar
RCL
RCL is offline
So I just bought a 06 g35 coupe 6mt and the e brake was very loose. All I did was tighten that bolt near the parking brake handle and the e brake handle only goes up a few clicks now as opposed to the 15 or so it would before, before adjustment the e brake handle would make almost a 90 degree angle with the center console! Now its about a 30-40 degree angle when engaged.
  #38
Old 09-30-2013, 06:18 PM
Babyseat's Avatar
I also just tightened that bolt under the coin holder on my 05 while I was at a hotel took maybe 5 minutes including pulling out the socket set I keep in the trunk and making sure it wasn't too tight
Great DIY Thanks for the help!
  #39
Old 09-30-2013, 06:20 PM
Babyseat's Avatar
Sorry duplicate post
  #40
Old 09-30-2013, 06:21 PM
Babyseat's Avatar
Wow 3 times lol sorry phone messed up
  #41
Old 09-30-2013, 06:31 PM
Babyseat's Avatar
And again my bad
  #42
Old 01-01-2015, 08:50 PM
BrazenBunnies's Avatar
Originally Posted by j 4 lD
Yea but I get what you're saying. Other cars, like my buddy's Acura TL, have two annoying *** screws that secure the rotor to the hub assembly. They sit flush with the rotor and require an impact wrench to remove. I helped him replace his rotors and those two screws on each rotor were the biggest PITA! We literally spent 1 hour on each rotor and basically ruined each screw.
Home Depot sells a tool that when you hit it with a hammer, it loosens a Philips screw. I bought it for just this purpose and it works well.
  #43
Old 01-01-2015, 09:46 PM
I just went out to do this adjustment. When I went to loosen the locking nut on the foot pedal, I noticed the cable was already loose. So I tightened the screw and raised each rear wheel, making sure they could rotate when parking brake was off, and not when it was on. It was quite easy, I don't know if there is any problem with how I did it, but it seems to work fine and I did not have to take the wheels off or take anything apart.
  #44
Old 04-12-2015, 07:25 AM
tha_ape's Avatar
G35 6MT Coupe
I was doing my rear brakes and decided to be a masochist and do the parking shoes as well. Springs aside, the hardest part of the job was getting the old rotors off of the car. I was banging on them with a freakin' sledge and they werent budging. I ended up spraying copious amounts of WD-40 and letting it soak for a couple hours. I put anti-seize on the darn thing when I put the new rotor on.
Back to the topic though. After doing the shoes and messing with that star wheel, I was done. Having never dealt with drums before there was a bit of a learning curve and it was a real PITA rotating that star, checking the tightness, repeating... It didnt help that I had 1 wheel on the ground. Eventually I got it tight and backed the star off about 3 clicks. Once that was done I went in the cabin to adjust the e-brake, but found it was pretty good. No adjustment needed
In all honesty, I probably could have just tightened up the handle and been fine, but I figured while I had my rear rotors off, I might as well change the e-brake shoes. Its going to be a while before those rear rotors come off again.
kinetek
08-03-2015 04:25 PM
Wayne9011
07-27-2015 11:25 AM
itschuckster
07-25-2015 08:07 AM
netcbc
Steering & Suspension CDN
07-24-2015 11:25 AM
Quick Reply: DIY: Parking Brake Adjustment ('05 6mt sedan)
