DIY:g35mods.com Lug Bolt Removal and installation for spacers.
I just did this write up for my front spacers. Please comment and stuff.
The rear are a little more challenging. I did all 4 corners last week. For the rear, jack up both sides and pull wheels off. Pull off the calipers, then rotors. Now looking at your e-brake hardware, on the back side there is a little more room where you can pound out the old studs and slide the new ones in. The nismo 60mm were a little tight going in, if you get it started in the hole and use your hands to turn the hub it will pop in.
netcbc
Wheels & Tires CDN
08-25-2015 09:42 AM
RAVSPEC
Wheels & Tires-Vendor
08-05-2015 03:53 PM
