Another G sedan with 350z suspension *PIX*
Old 03-11-2008, 10:00 AM
n15m0's Avatar
I understand that the thread starter has used front 350z struts and springs on his sedan, but will the rear 350z struts and springs be a straight fit for the rear as well? Mine is an 05 sedan..
Anyone have pics of a full 350z suspension setup in an 05 G Sedan front and rear?
THX.
  #137
Old 03-11-2008, 10:23 AM
naughty240's Avatar
It looks the same. All the springs,shocks,struts on the z, g coupe and g sedan are interchangeable. The rear is a shock not a strut. Really the only time its an issue is if your just changing your springs. If you wanna change both you can get a matching set right from a 350z and pop it right in.
  #138
Old 03-16-2008, 11:28 AM
SickGs's Avatar
Why is everyone all over recycled stock springs? Get your bankroll up and treat your G to what she deserves.....
But the car looks good....I would put an 05, 06 front bumper on it gives it a little bit meaner look with the drop without being over the top
  #139
Old 03-17-2008, 12:35 PM
jimmyc13's Avatar
1) They look great compared to our OEM spring height
2) They handle & corner better than our OEM springs
3) They help out fellow G/Z owners by taking them off their hands (if they go w/ aftermarket springs)
4) They're much cheaper than going with an aftermarket setup
5) They're a practical drop for our cars IMO. Slammed cars look hot, but in my world, living in New England & having 2 kids, it's not practical to go any lower (i've already cracked my 2 front splash guards from being lowered). New ones on the way.....
6) Recycling is good for the environment
7) Why not?
The following 2 users liked this post by jimmyc13:
6klub (10-15-2021), rmyc (06-20-2012)
  #140
Old 03-17-2008, 01:10 PM
naughty240's Avatar
amen 55 bucks shipped cant go wrong.
  #141
Old 03-17-2008, 05:14 PM
Swivel's Avatar
Moderator
What Jimmy said.
  #142
Old 03-18-2008, 01:36 PM
g35guy86's Avatar
I drove my car 90k miles before I sold it for a coupe and the suspension was still riding strong. Once again I definitely recommend this mod for your sedan. Im look for this kind of drop of my coupe now. Still searching...
  #143
Old 03-19-2008, 01:32 AM
sixthGear's Avatar
i have and '06 Sedan without sport suspension, will '07 350Z springs and '03 Sways/Shocks fit/work?
  #144
Old 03-25-2008, 05:50 PM
Texan1's Avatar
Q50 Red Sport 400 RWD
Colored-dots for ID purposes
For 350Z springs--will drop a sedan 1" on all 4 corners.
Fronts are 314 spring rate and have 1 pink dot and 1 orange dot. Coils are tighter and most have the rubber sleeve on them.(2007-2008 models have 1 white and 1 orange dot) Tech farmer mentioned some z springs front may have only 1 pink dot z front are confusing
Rears(revised,2004.5+) are 427 spring rate and have 2 red dots and 1 purple dot.
(2007-2008 models have 2 red dots and 1 blue dot)
Rears(unrevised 2003,some 2004) are 342 spring rate and have 2 red dots and 1 white dot.(1 white dot)
Attached Thumbnails Another G sedan with 350z suspension *PIX*-2003zsprings.jpg   Another G sedan with 350z suspension *PIX*-zoemrevisedsprings003es8.jpg   Another G sedan with 350z suspension *PIX*-2008zfront.jpg   Another G sedan with 350z suspension *PIX*-zsprings.jpg
fagan59 (05-08-2019)
  #145
Old 03-25-2008, 05:51 PM
Texan1's Avatar
For coupe springs: Lowers a g sedan 1/2" on all 4 corners
Fronts: 314 spring rate with 1 white dot.(1 white dot)
Rears from a coupe with OEM 17s/18s: 342 spring rate with 3 red dots
Rears from a coupe with OEM 19s: 427 spring rate with 2 red dots and 1 purple dot
Attached Thumbnails Another G sedan with 350z suspension *PIX*-342rearcoupe3reds.jpg   Another G sedan with 350z suspension *PIX*-coupe314and427springs.jpg
The following 2 users liked this post by Texan1:
dj714 (10-05-2012), fagan59 (05-08-2019)
  #146
Old 03-25-2008, 05:52 PM
Texan1's Avatar
I believe the above to be accurate, if not feel free to chime in.
(mouse over the name of pic, to see what you're looking at)
Hopefully this helps with sedan owners configuring a front z spring and rear coupe spring set up.
Spring rate reference from sticky:
Oem linear springs
G35 coupes with oem 17’s & 18’s
G35 sedan’s with sport suspension
350Z’s 2003/2004
Front:314 Rear:342
Oem linear springs
G35 sedan's with non sport
Front: 283 Rear: 308
Oem linear springs
G35 coupes 2005/2006 with oem 19’s only
350Z 2004.5 to 2008
Front:314 Rear:427
additional comments in this thread
https://g35driver.com/forums/showthr...39#post2833639
  #147
Old 03-26-2008, 07:38 AM
sixthGear's Avatar
appreciate it, great write up!
  #148
Old 03-26-2008, 09:03 PM
TechFarmer's Avatar
Here is some more info:
Front 350z spring with the 314 spring rate may have only 1 pink dot or it may have 1 pink and 1 orange dot.
G35 Sedan sports suspension:
Front: 314 spring rate, 2 orange dots
Rear: 342 spring rate,1 blue and 2 yellow dots
350Z Roadster (convertible):
Front: 314 spring rate, 1 light blue dot
Rear: 427 spring rate, 1 light blue and 2 red dots
G35x Sedan (all wheel drive):
Front: 283 spring rate
Rear: 355 spring rate
  #149
Old 03-26-2008, 09:10 PM
TechFarmer's Avatar
Front Spring height comparison
Here is a picture comparing the front spring heights. The G35 coupe spring is about 1/2" shorter than the sedan and the 350Z spring is about 1" shorter.
350Z -- G35 coupe -- G35 Sedan (sports suspensn)
Attached Thumbnails Another G sedan with 350z suspension *PIX*-front_springs_350z_g35coupe_g35sedan-sport.jpg
  #150
Old 03-26-2008, 09:14 PM
TechFarmer's Avatar
Rear Spring height comparison
Here is a picture comparing the rear spring heights. The G35 coupe spring is about 1/2" shorter than the sedan. The 350Z spring is just a little more than 1/2" shorter than the Sedan spring.
350Z (revised) -- G35 coupe -- G35 Sedan (sports suspensn)
Attached Thumbnails Another G sedan with 350z suspension *PIX*-rear_springs_350z_g35coupe_g35sedan-sport.jpg
Quick Reply: Another G sedan with 350z suspension *PIX*
