600WHP, Killed my JWT Clutch
So,
I did a MT swap and it definitely took some getting used to for the first few k miles, but my pressure plate is cooked 1.5 oil changes into my swap
I'm not sure the JWT was a good choice for 600 Wheel++ Torque
What are you 600+ Guys using?
Or should I just L2 Drive noob gg lol.
So,
Grab like an SOB.
seymore4 (02-07-2015)
Maybe a 6puck but not sure it'll be up to the job.
What's your concern with a twin plate? I've had a hd, 6 puck and run a twin plate now. The cool part with the twin plate is you only need to replace the disks and they usually come with a flywheel as a set
its not just about being a twin disc, but you need to look at the torque handling when clutch shopping. most clutches are rated in max torque. Also the twin should be easier to drive than a harsh 6 puck, just more expensive.
So,
JG_G35
Engine - Intake/Fuel
09-07-2015 09:35 PM
